How to clean the filter door - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
You can use a brush which can fit into while it is rinsed or if you have a JET washer it can do a good job.
Posted on Dec 31, 2012
HW5513M Hoover washer dryer has a coin filter which I clean regularly, but washer door seal (and hence laundry) has wet fluff buildup. How do I prevent this?
There should be a lint filter somewhere in the dryer. Even with a lint filter you are likely to get accumulation around the door seal.
Aug 14, 2016 | Hoover Washing Machines
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
My menumaster UC11E2 continually shows "cln fltr"
The filter is on the buttom of the front door. take it out and wash it. Just look under the door.
Apr 10, 2011 | Microwave Ovens
How do I clean the washer pump filter in my GE-WCVH6600HGG?
please go through this http://www.youtube.com/watch?v=x7rJkWE0nN0
Instructions:
  • Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running
  • Open the pump access door with a coin. Remove the pump filter by turning it counterclockwise and pulling it out.
  • Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean.
  • Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
  • i hope this helps you ,thank you
    Feb 10, 2011 | GE Washing Machines
    CHECK FILTER LIGHT COMES ON. i HAVE CLEAN THE FILTER AND HAVE TAKE A FILTER BRUSH AND CLEAN THE COMPARTMENT BUT THE MESSAGE KEEPS COMING UP.
    The filter and compartment are only a portion of the exhaust system. Make sure you clean the pipe from the dryer to the out doors and clean the exhaust fan below the filter.
    Good luck.
    Jan 24, 2011 | LG DLE5977 Electric Dryer
    How do i clean the filter
    It is very simple,
    Open the door and pull out the filter from the door frame,
    No need to wash it only brush it and it enough
    Dec 23, 2010 | Zanussi TD4112W Electric Dryer
    Machine states the filter needs to be cleared but i cannot locate it.
    It is easy to clean it if it is front load there will a small door will be present at the bottom corner of the front door just open that door and one lever will be present just pull that then you can rotate the plastic knob in anti clockwise it will come out just clean the plug filter then refix it properly
    May 16, 2010 | Washing Machines
    Sometimes water doesn't get hot.
    Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
    Apr 20, 2010 | Rheem Tankless Hot Water Heater...
    What is error code c2 11?
    Sep 20, 2009 | Water Heaters
    Code on display OE
    Just got the same problem. Found out there is a filter on the bottom of the machin that collects everything. It was plugged bad. There is a door on the front bottom left open door unscrew filter (the bigger object in the door.) Clean filter and wala.
    Oct 24, 2008 | Washing Machines
    Washing Machines Logo
    12 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
