Question about Air Tools & Compressors
All trade air compressor 5 hp
My alltrade Trades Pro 5hp air compressor 835268 wont build up much pressure
2 Suggested Answers
  • 332 Answers
SOURCE: I have moisture in my air flow, and I was
On the bottom or the tank there should be a drain valve
Open it, then start your compressor, allow the unit to run for 2 or 3 minutes this will dry it out
We drain the compressors in our shop daily to avoid water build up and the rust that comes with moisture
Over time you can rust a tank through, which will never happen at a good time and could be dangerous
Posted on Mar 31, 2010
Testimonial: "This helped me very much. Drained the moisture(very little) and tightened up some connections, and i was good to go. Thanks!!"
Trades pro air compressor
Sounds like rod is seized on the crank... Oil lubed?
Apr 23, 2013 | Alton 3 HP 11 Gal Air Compressor
All Trade 5 Gal just humms wont turn on
The start capacitor has gone bad. Needs to be replaced. That's what's inside that bump on the side of the motor.
Mar 25, 2013 | Alltrade 830241 5 Gallons 3 HP Twin Tank...
5 gallon compressor tries to start then stops
it sounds like the unloader is not working so it's trying to start with to much head pressure. One cause is a bad check valve another is a bad pressure switch. Those are the more common problems.
Jan 04, 2013 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
My compressor builds up to preset pressure just fine. My problem is after the pump shuts off, the air leaks down at the valve on the pressure switch. I have changed pressure switches and still have the...
This switch is only rated for up to 2 HP at 240 volts and 1-1/2 HP at 120 volts. Using 3 phase power, you can go only up to 3 HP. That would not cause the problem that you discuss, but it is an unsafe condition.
Some Square D switches have a small relief valve so that when the compressor reaches pressure, the motor stops and the relief opens and lets pressure out of the compressor cylinder. Does your switch have that and might that be what is "leaking"? I believe that if the compressor is tight that the leak would stop rather quickly.
Dec 11, 2010 | Square D 9013FHG14J52M1X Air Compressor...
My pipe trades pro when solving a rolling offset only gives me 0.0 degrees
Hi jlight49,
Your Pipe Trades Pro calculator from Calculated Industries comes with FREE technical support:
Live chat - http://messenger.providesupport.com/messenger/calculated.html?ps_s=PJ2Ks9f4GXh8
Email - techsup@calculated.com
Phone - 1-800-854-8075
It is hard to tell from the description of your issue, but when working with a rolling offset, the [Angle] will show 0.00. All the rolling offset outputs are accessed through the second function of [Travel] which is labeled as [Roll].
The key sequence is:
-enter your rise into [Offset]
-enter your advance into [Run]
-enter your roll into [Roll] by pressing [Conv] [Travel]
-press [Travel] repeatedly to see the rolling offset outputs, starting with Length, followed by Fitting Degree, etc.
Contact technical support and they will help you out!
Thanks.
Sep 15, 2010 | Calculated Industries Pipe Trades Pro 4095...
Mar 31, 2010 | Air Tools & Compressors
I ran my up-right 5hp compresser out of oil. will
YA YOU CAN DO YOU HAVE A OIL LEAK LD CK THAT IF YOU NEED PATR NUMBERS SEND ME THE MODEL NUBERS AND ILL GETEM FOR YOU AND TELL WERE TO GETEM
Oct 22, 2009 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
67 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
