Question about Casio Exilim EX-S500 Digital Camera
EX-S500 lens stuck closed.
Hi. My EX-S500 lens is stuck closed. It makes a grinding noise and tries to move but cannot open. This happened once before and some shaking and multiple tries unstuck it. Now it seems hopeless. What can I do?
Gareth
Lens is jamed i0n an angle in the partially closed position.
  • Casio Master
  • 13,433 Answers
The lens gears are possibly stuck, try tapping it on the sides, you could attempt to help to lens with your fingers but carefully. as it is a fragile camera.
If noting helps the camera will need to be taken apart same with the lens and put back together, you can get a free repair estimate from www.advancecamera.com/repair
Posted on Jan 18, 2009
Compact digital camera lens assembly jammed after dropping
i worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Dec 27, 2009 | Casio Exilim EX-S500 Digital Camera
If you camera is in warranty then I recommend you contact the manufacturer for an RMA so that you may return it for repair.
All digital cameras selling for under $500 have a failure/problem rate higher than what most of us consider acceptable. If you are outside the manufacturers warranty but you have a retailers extended warranty then contact them. (I believe that extended warranties rarely provide a good return on investment. However, for digital cameras my experience shows a better investment because of the rate of failures with prolonged ownership...I have no vested interest in extended warranties.)
If you do not get satisfaction from the manufacturer or retailer; then regrettably you have few reasonable choices. With your next camera you may decide to include some thoughts herein during your purchase.
Jan 10, 2009 | Casio Exilim EX-S500 Digital Camera
Ex s500 - camera lens stuck in out position.
Sounds like you have a defective motherboard, because it wasn't dropped, it is not usually a lens issue. This is a camera repair place, they specialize on small cameras like casio exilims. I've had a Canon sd750 fixed with them for the exact same problem. The website is : camera repair nyc
Jan 03, 2009 | Casio Exilim EX-S500 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Lens Error
What do you do if it's a lens error?
Nov 24, 2007 | Casio Exilim EX-S500 Digital Camera
The lens won't come in and wont turn on.
The lens gears are stuck/stripped. The S500 has horribly soft gears. I have a nice stack of bad S500 lenses myself. Unfortunately, the lens will need to be replaced. The only cost effective option is a good used lens from a camera on eBay that maybe has a bad LCD or something.
Aug 20, 2007 | Casio Exilim EX-S500 Digital Camera
Stuck Camera Lens
You could try the Casio Tech Support team, but if as you suspet it is a matter of dirt- there is nothing to be done except replace the camera- the cost os shippin and examining the camera etc. will come close to its replacement.
Jun 25, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
