Question about Bosch Nexxt WTMC 3300 Electric Dryer
BOSCH Electric dryer with blinking start
This dryer is about 8 years old. The Start Light has started blinking and will not start. I removed the drum, and cleaned out the filter and air chamber. I checked the thermal cutoff on the heater. That is fine. My question is am I supposed to have a reading of some kind on the thermistor near the heater? I also did not get a reading on the door switch, so I jumped it out at the control, and still have blinker, no start. I'm lost as to what to check now, unless the control is bad. Any one have any ideas on something I missed to determine where this problem lies..? Thanks Bob H
  • Bob Henderson
    Bob Henderson Jan 02, 2013
    I suspect that I may not have reset the belt switch, which will disable the motor. I won't know for sure until Jan 2nd when I return to the Residence
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: Bosch nexxt 500 series dryer
I have a Siemens dryer and few days ago it stopped heating, but the drum rotates. The problem was because of a safety reset button that went off. On the Siemens (WT dryer series), it is a red button behind the dryer.
Press the red button and it will restart. I might have started a fire, if not for this safety switch.
A similar reset button must have tripped on the Bosch dryer.
FYI: Remember Bosch and Siemens share their technology.
Posted on Aug 31, 2008
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
svicari124
  • 21 Answers
SOURCE: I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Posted on Sep 20, 2009
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis electric dryer, 3 years old, dryer drum won't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Out hotpoint dryer is 8 years old and juist
Sounds like the drum bearing or shaft is worn.
Remove rear panel of dryer, you should see the drum shaft, check for wear here.
Jan 17, 2010 | Hotpoint Dryers
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch gas WTMC 6500 dryer won't start. Start/Stop light blinking
I have 5 years old Bosch gas dryer. It will not start today, start/stop is blinking and it will not start. What can be the problem.
Feb 21, 2009 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch WTM C3300 Dryer
I don't own this model of the Bosch dryer, but my guess is that your hot air flow path is partially blocked with lint or something else. Our heating/air flow element was blocked with a errant latex club hit the elements. I cleaned the flow path and removed the heater obstruction with good results for nearly a year to date.
Oct 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer won't start...
if timer is timing down then it has power so fuse is ok. there is no internal fuse. two things to check if you can hear a low humming noise when drum should be turning, then the motor capacitor is faulty - very common fault and part not dear. no need to get bosch part - you should be able to source locally.to test for this fault, take top off and push the drum. if it starts turning then this confirms the fault check also door catch - this operates an internal switch nand if catch is broken then appliance will not start
Apr 18, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
131 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
