Question about Durabrand DUR7 Portable DVD Player
Dvd player My DVD player will not read the any dvd. I tried the q-tip thing and pushing the little black button down did not work. The little red eye will not come on.
  • 97 Answers
To test the laser pick-up, push the lid swith down to simulate to unit it is closed. Turn unit on to see if the pick-up goes to the middle, tries to focus and the laser can be seen on the lens. If the laser is not present during this operation, bad pick-up. Replace entire unit due to replacement cost of pick-up vs new unit. If it is 70% cost of part vs the new unit, I would opt for a new one. If you are not familiar with a repair of this nature, please do not try. There are more adjustments than just a new pick-up.
Posted on Jun 25, 2007
Philips portable dvd player (white tab or) wire strip is out
This is a really easy fix. There should be a little black bar that is right about the point that the white tab looks like it should go. The black bar will snap into place or pop up if yours is already snapped down. I took the entire DVD player casing off to re-attach this tab but it could probably be done without that in retrospect. I needed the room to maneuver however. The blue tip will insert just below that black bar and when you've met resistance (which will be rather soon, I could see all of the other color stripes) snap the black bar down. The tab should be held in place and the DVD should read again. Hope that helps!
May 01, 2012 | Philips PD700 7 in. Portable DVD Player
Where do i put the dvd in at and how to turn it on
  1. Press the open/close latch on the front of the DVD player.
  2. When the screen drops down look up at the compartment where it was. Press the upper right hand corner button on the DVD player to drop the little black tray.
  3. Just place the DVD in upside down and click it into place.
  4. Now close the little black try.
  5. The unit powers up as soon you drop the screen down. You can also power it on with the remote power button which is all the way up and all the way to the left on the remote.
regards, Tony
May 20, 2011 | Directed OHD1040 Car DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
DVD player - Memorex DVDP 1102 - "NO DISC" message
ok get a cotten swab and put a little alchohol on the tip now gently rub over and around the casing of the lens...gently trying to lift it back up into posistion (your son pushed it down into its casing....You might also try droping it upside down on a soft couch pillow to dislodge the lens (This method has worked for me ) ps its just a hair!
Dec 11, 2008 | Memorex MVDP1102 Portable DVD Player
CyberHome DVD player not responding...
The internal power supply has failed and is shutting down each time you try to turn it on. To remove your DVD there is a slot on the bottom labeled: Emergency.... with an arrow pointing the direction you need to push a lever to open the drawer. With good lighting you'll see the tab you need to slide over. Use a small flat blade screwdriver and the drawer will open enough to grasp it and pull it open. The power supply will need to be repaired, but it may have caused other damage and may be more expensive than buying a new player.
Mar 06, 2008 | Cyberhome CH-DVD 300 DVD Player
Change screen on portable dvd
you should have received a warranty with it take it back to the store you received it from and work things out
Jan 24, 2008 | TruTech PVS12701 Portable DVD Player
Black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Durabrad DUR-1700 - No Disc
turn on the power and open the dvd axcess door, inside where the dvd goes is a small little push down switch, push this down, it is in the upper right side. this will let you see if the laser is powering up,if you see no red light ,your laser is bad. hope this helps
Aug 06, 2007 | Durabrand DUR-1700 Portable DVD Player
I change settings
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
Nov 28, 2006 | Cyberhome CH-DVD 300 DVD Player
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Durabrand DUR7 Portable DVD Player Logo
52 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
