Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint RFA 60 Refrigerator drain problem
The drain in the back of my fridge no longer drains. I slid a wire down it to see if it was blocked but hit what sounds like a plastic ledge . Is this normal or should it run straight down to the condenser tray?
  • 2 more comments
  • Anonymous Jan 18, 2009
    My fridge has the same drain problem, anyone help?
  • tiny_storer Jan 21, 2009
    I need to defrost the freezer first to see if this will work.
  • Anonymous Jan 30, 2009
    I have the same problem. I have cleared mine a few times by defrosting and then clearing drain with a long wire until water flows through ok, however it freezes up again too quickly, a pain really. I am considering buying a new fridge freezer but they seam to all be new sizes and my height gap is 163cm so choice is limited.
  • ianlockwood Jan 30, 2009
    I am confused by the solution offered. The drain hole is at the back of the fridge, this hole leads, I assume, to a tube within the back of the freezer which opens out to drop water onto the plastic tray on top of the compressor unit where it can evaporate. The solution says take the back off the inside of the freezer however the freezer compartment is a single moulded box and there is no panel to remove?
  • 306 Answers
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Posted on Jan 18, 2009
Check that the light is going out when closing the door . I had a similar problem of freezing under the salad storage containers. the light was warming the interior of the fridge. Too much water for the Evaporation of water in the drain hole.
Posted on Jul 26, 2009
I have finally cleared the drain gutter, using salt & warm water. Next time I'll shoot the RFA60 and buy a decent f/f.
Posted on Dec 11, 2011
Hi there water building up and flooding back from my fridge drain hole.hotpoint model number rfa07
clean ice from drain hole then take a wire hanger and cut it to about 3-4 inches , wrap one end around defrost element anf the other end down the drain hole . use a turkey baster to force VERY hot water down drain hole to clear build up and debris
Feb 24, 2013 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water is dripping down the back wall of my hotpoint refrigerator model # CTX21DA. The water collect at the bottom and drips onto the floor. How old is the refrigerator and what would the cause be for...
The problem is relatively simple to repair. The drain tube in the freezer is blocked so the water will drain down the back of your fridge. Often the drain gets blocked by ice build up. The defrost circuit in your fridge has failed and ice is building up on the evap coil in the freezer. When the ice builds up, it blocks the drain tube. The typical failures of the defrost is the timer failing to advance or the heater is burned out. Being that said it was probally manufactured at least10 years ago, and certainly a new refridgerator would be more energy efficient and cheaper to operate than using a 10 year old model. Whether you should repair or replace it depends on whether you have the money to replace it. Hope this helps you.
Dec 06, 2010 | Hotpoint Refrigerators
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Sep 04, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Water in fridge
does this fridge have a gulley at the back with a drain hole in the middle? if so, the drain is blocked, push something flexible down the drain till water flows away freely
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
1,660 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
