Shaw digital remote control 2020B0-BX, I cannot change channels??
Shaw digital remote 2020B-BX with Toshiba flat screen, remote only powers on and off tv and allows volume control, however I cannot change channels?????
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
Need code for Shaw remote
Take your Shaw Remote Control, and read the instructions on the back. Follow those instructions. If that does not work, just telephone Shaw, and ask for Technical Support for TV, and a customer representative will walk you through the process.
Feb 11, 2014 | Acer Televison & Video
No signal + snow on screen
If you have a "non-High-Definition" Shaw Digital Terminal, tune your TV to Channel 3.
If you are using "component-input/output" or "composite-input/output", use the "Source" (or "Input") button on your TV's remote control to select the correct "input".
Feb 08, 2014 | shaw.ca
We cannot change the channels
On the Shaw remote control, press the 'CBL' ("cable") button,
and then press the Channel-Up or Channel-Down buttons on the right-hand edge of the remote.
Got good batteries inside the remote control?
Oct 15, 2013 | shaw.ca
Www urcsupport com
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Sep 23, 2013 | Televison & Video
Free samsung tv hook up diagrams
If you have the "basic" Shaw Digital Terminal, use the TV's remote to set the TV to channel 3. Use the Shaw Remote Control to "channel-up" and "channel-down".
Sep 03, 2013 | Audio Players & Recorders
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
Remote issues with shaw cable box - volume, channel selection and power - how to sync the remote with the tv and/or shaw box/remote?
Jan 29, 2013 | Acer AL2671W 26 in. LCD Television
Can't see image with shaw pvr on toshiba 32hl57
I presume you followed the instructions in the TV manual during hookup and did not hook up with the units powered up and did select the correct input with the remote?
If you have another unit that uses HDMI try a direct hookup with it to see if the HDMI input is working.
HDMI units do not like being hooked up when units involved are powered up and on--seen more than a few where this was the problem and it is worth a try if the Owner Manual does not help you.
Apr 10, 2012 | Toshiba Televison & Video
Vizio TV remote is in conflict with Shaw TV remote. When the TV is on, the Shaw bow and the shaw remote control would not work. I turn both systems off, then turn the box on with the remote, select a...
You need to "program" your Shaw remote to control your TV, including the volume up/down on the remote.
Mar 09, 2011 | Vizio M420VT 42 in. LCD HDTV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
