Question about Pentax Optio 60 Digital Camera
Optio 60 Card Locked
I can't seem to get my camera to work, every time i turn it on it says card locked. It will not let me take a picture, or erase any pictures. Can anyone help me with this?
If it says card locked. take out your memmry card on the side of it should be a white little strip you probably swtiched it to locked! you can unlock it by clicking it up!!!
Posted on Nov 12, 2008
    Genius:
  • 2,985 Answers
Check your manual - there is mechanism where by you are prevented from accidentally erasing images. It would appear you have unitentionally activated this How do you switch if off? Only the Manual will tell you Or Pentax Technical Support Team
Posted on Jun 23, 2007
SOURCE:
Pentax camera card is locked
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 02, 2012 | Pentax For Optio M85 E85 E60 Digital...
I have a pentax optio e50 , when i turn it on says that card is locked , yet the card inserted is on unluck i cant not take any pictures.
These cards usually have little tabs on them to "lock" and "unlock" them. Try moving the switch and see if that works. If not, you can also try using the card on another camera or a computer (through a card reader) to see if that works.
Feb 28, 2011 | Pentax Optio E50 Digital Camera
When trying to delete pictures from camera directly, it says 'card locked' and we can't get it cleared.
The SD memory cards used by this camera can be locked by a small switch on the edge of the card. Take the card out of the camera and examine it closely. the switch should be moved towards the edge where the electrical contacts are to unlock it.
Oct 20, 2010 | Pentax Optio 60 Digital Camera
When ever I turn on the camera, the display shows "card locked". I can hit the > button and it appears to unlock it, since pictures now show up. But, whenever I try to do anything else it locks back...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 11, 2009 | Pentax Optio 60 Digital Camera
My card is locked. what shall I do pentax optio
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2009 | Pentax Optio 60 Digital Camera
Keep getting card locked on my display screen
Hi there.
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
May 29, 2009 | Pentax Optio 60 Digital Camera
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Pentax Optio 60 Digital Camera Logo
74 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
