Question about Microsoft Xbox 360 Console
Blue lines on screen sometimes appearing as blue dots
Happens on any game .sometimes screen goes purple green or blue
  • Anonymous Mar 03, 2009
    white dots/lines appearing on my tv
You must change the card of vga ( card screen )
Posted on Jan 18, 2009
Dots appear on the touch screen
hi lea, does this dots and lines appears occasionally or it just stays there? because if its permanently there, then you might need to replace the lcd part of the lower screen (not the touch screen part) but if its occasionally, then try to see if it happens when your on the lowest brightness or highest brightness, if it is then you will have to adjust the variable resistor on the motherboard of the DS,let me know if you have to do this.
Dec 20, 2011 | Nintendo DS Lite Console
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Puzzle 100 line error
I think your game file is corrupted erase it and start all over no other way
Aug 23, 2009 | Nintendo Professor Layton & the Curious...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Black lines 1/8 of an inch apart going down my screen when playin
I had this happen a few times, then after a while it stoped working all together. In the end I was getting the E74 message code appear when I turned on my xbox 360.
You'll probley get this happen with yours soon, the E74 code means theres a problem with your visual display.
Sometimes it can be as simple as changing your HD Lead or scart lead, whatever your using. If you know someone else with a xbox try theirs.
If this doesn't work you'll have to send it off to mircosoft, it will be free if your still under warrenty, if not I think it's about £100+
Or you could go on www.cd24-7.co.uk and buy one of their DIY kits.
Hope this helps.
Jan 11, 2009 | Microsoft Xbox 360 Console
I want cheat codes of sims 2 pets
  • Cheat Gnome While at home or on a lot, press L1(2), R1, X(2), Up. Then, enter one of the following codes to activate the corresponding cheat function:
      10,000 additional Simoleons Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome. Select the Cheat Gnome, then cancel the selection. Press Up, Left, Down, Right, R1 again. A "Give Sim Simoleons" option should now appear.
      Pet Points Enable the "Cheat Gnome" code, then press Triangle, Circle, X, Square, L1, R1 while playing the game. A "Pet Points" option will now appear on the Cheat Gnome.
      Pet Emporium fully upgraded Enable the "Cheat Gnome" code, then press Right, Down, Right, Up, Right, Down, Right, Up while playing the game.
      Advance time by 6 hours Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome.
  • Alternate opening sequence At the EA logo, press X, Circle, Triangle.
  • View developers At the credits screen, press Right, Left, Up, Right, Down, Right, Down, Right.
  • Bonuses At the codes screen under the "Game Options" menu, enter one of the following codes to activate the corresponding cheat function:
    Result Code
    Collars
    Black Dot Cats ZZZ11ZZZ9Q11Q91ZB1A or EEGJ2YRZQQ1IQ9QHA64 Black Dot Dogs ZZZ11ZZQHZ11Q91ZB1A or EEGJ2YRQZZ1IQ9QHA64 Black Smiley Cats ZZZ11ZZQ9Z1AQ91ZB1A or EEGJ2YRQQZ1RQ9QHA64 Black Smiley Dogs ZZZ11ZZZ9QAAQ91ZB1A or EEGJ2YRZQQARQ9QHA64 Blue Bones Cats ZZZ11ZZQHZAAQ91ZB1A or EEGJ2YRQZZARQ9QHA64 Blue Bones Dogs ZZZ11ZZZHZ11Z91ZB1A or EEGJ2YRZZZ1IZ9QHA64 Blue Camouflage Cats ZZZ11ZZZHQ11Q91ZB1A or EEGJ2YRZZQ1IQ9QHA64 Blue Camouflage Dogs ZZZ11ZZZHZ1AQ91ZB1A or EEGJ2YRZZZ1RQ9QHA64 Blue Star Cats ZZZ11ZZQ9Z11Z91ZB1A or EEGJ2YRQQZ1IZ9QHA64 Blue Star Dogs ZZZ11ZZQHQ11Q91ZB1A or EEGJ2YRQZQ1IQ9QHA64 Green Flower Cats ZZZ11ZZZ9ZA1Q91ZB1A or EEGJ2YRZQZAIQ9QHA64 Green Flower Dogs ZZZ11ZZQHZ1AQ91ZB1A or EEGJ2YRQZZ1RQ9QHA64 Navy Hearts Cats ZZZ11ZZZ9Z11Q91ZB1A or EEGJ2YRZQZ1IQ9QHA64 Navy Hearts Dogs ZZZ11ZZQ9Z11Q91ZB1A or EEGJ2YRQQZ1IQ9QHA64 Orange Diagonal Cats ZZZ11ZZQ9ZA1Q91ZB1A or EEGJ2YRQQZAIQ9QHA64 Orange Diagonal Dogs ZZZ11ZZZ9Z11Z91ZB1A or EEGJ2YRZQZ1IZ9QHA64 Pink Vertical Strip Cats ZZZ11ZZQ9QAAQ91ZB1A or EEGJ2YRQQQARQ9QHA6 Pink Vertical Strip Dogs ZZZ11ZZZHZA1Q91ZB1A or EEGJ2YRZZZAIQ9QHA64 White Paws Cats ZZZ11ZZQ9Q1AQ91ZB1A or EEGJ2YRQQQ1RQ9QHA64 White Paws Dogs ZZZ11ZZZ9Q11Z91ZB1A or EEGJ2YRZQQ1IZ9QHA64 White Zebra Stripe Cats ZZZ11ZZZHQ11Z91ZB1A or EEGJ2YRZZQ1IZ9QHA6 White Zebra Stripe Dogs ZZZ11ZZZHZ11Q91ZB1A or EEGJ2YRZZZ1IQ9QHA64
    Fur colors
    Blue Cats ZZZ11ZZQHZA1Q91ZB1A or EEGJ2YRQZZAIQ9QHA64 Blue Dogs ZZZ11ZZQ9Q11Z91ZB1A or EEGJ2YRQQQ1IZ9QHA64 Deep Red Cats ZZZ11ZZQ9QA1Q91ZB1A or EEGJ2YRQQQAIQ9QHA64 ° Deep Red Dogs ZZZ11ZZQHQ1AQ91ZB1A or EEGJ2YRQZQ1RQ9QHA64 Goofy Cats ZZZ11ZZQHQ11Z91ZB1A or EEGJ2YRQZQ1IZ9QHA64 Goofy Dogs ZZZ11ZZZHZAAQ91ZB1A or EEGJ2YRZZZARQ9QHA64 Green Cats ZZZ11ZZZ9QA1Z91ZB1A or EEGJ2YRZQQAIZ9QHA64 Green Dogs ZZZ11ZZQHQA1Q91ZB1A or EEGJ2YRQZQAIQ9QHA64 Light Green Cats ZZZ11ZZZHQ1AQ91ZB1A or EEGJ2YRZZQ1RQ9QHA64 Light Green Dogs ZZZ11ZZZ9Q1AQ91ZB1A or EEGJ2YRZQQ1RQ9QHA64 Neon Green Cats ZZZ11ZZZHQA1Q91ZB1A or EEGJ2YRZZQAIQ9QHA64 Neon Green Dogs ZZZ11ZZZ9QA1Q91ZB1A or EEGJ2YRZQQAIQ9QHA64 Neon Yellow Cats ZZZ11ZZZHQAAQ91ZB1A or EEGJ2YRZZQARQ9QHA64 Neon Yellow Dogs ZZZ11ZZQ9QA1Z91ZB1A or EEGJ2YRQQQAIZ9QHA64 Pink Cats ZZZ11ZZQHZ11Z91ZB1A or EEGJ2YRQZZ1IZ9QHA64 Pink Dogs ZZZ11ZZZ9Z1AQ91ZB1A or EEGJ2YRZQZ1RQ9QHA64 Purple Cats ZZZ11ZZQ9ZAAQ91ZB1A or EEGJ2YRQQZARQ9QHA64 Purple Dogs ZZZ11ZZQ9ZA1Z91ZB1A or EEGJ2YRQQZAIZ9QHA64
    Fur patterns
    Bandit Mask Cats ZZZ11ZZQHZA1Z91ZB1A, TB6IPB1IAFDMRIQT6DG, or EEGJ2YRQZZAIZ9QHA64 Bandit Mask Dogs ZZZ11ZZQHQAAQ91ZB1A or EEGJ2YRQZQARQ9QHA64 Panda Cats ZZZ11ZZQHQA1Z91ZB1A or EEGJ2YRQZQAIZ9QHA6 Star Cats ZZZ11ZZZ9ZAAQ91ZB1A or EEGJ2YRZQZARQ9QHA6 Star Dogs ZZZ11ZZZ9ZA1Z91ZB1A or EEGJ2YRZQZAIZ9QHA64 Zebra Stripes Dogs ZZZ11ZZZHQA1Z91ZB1A or EEGJ2YRZZQAIZ9QHA64
  • Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    Xbox 360 freezes and Dotted Lines Appear
    hi
    my xbox has the same problem as above, also we have three red lights on console is there a solution?
    xbox live :leighjay
    Nov 26, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    819 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
