Question about Fisher and Paykel Dishwashers
Fisher and Paykel 913T not used for a long while now not working
I can choose the wash I want but pressing just brings" beeps". The machine hasnt been used for a long while. I have cleaned around the door seals. Any help would be appreciated.
SOURCE: Fisher and paykel 913T soft touch dishwasher leaking
I had the same problem and replaced the door seal. You need to remove the front door to do this. Requires some 'handyman' experience.
Posted on Jul 01, 2008
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Posted on Nov 07, 2008
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
SOURCE: How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Posted on Mar 13, 2009
stephanos18
  • 144 Answers
SOURCE: beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Posted on Mar 24, 2009
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
913T Dishwasher Stops after 10 seconds
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
May 24, 2012 | Dishwashers
Hi I am buying a MW512 but only have a cold water supply, does this model have an internal heating system so I can do a warm or hot wash?
Hi - Fisher & Paykels does not come with heaters fitted, the two hot/cold inlets are used in prortion to the settings of the wash cycle in use.
So with a cold tap only you would expect cold wash functions only, if you accidently chose a warm wash the machine will start beeping as there is nothing to bring the temp level to the expected setting.
Hope this helps you choose..
Jun 16, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1...
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Reset Fisher and Paykel washing machine
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
Feb 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
23 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
