Question about Whirlpool Dishwashers
Sediment in water/ blockage in the tubes
How do i take apart and clean parts to solve this problem?
  • chiassonx4 Jan 18, 2009
    water will not fill inside the washer how do i fix?
Will not empty water in bottom .
Posted on Jan 18, 2009
Why is it making loud mooing-like sounds when dispensing water?
The sound is water pressure flowing through the inlet valve and tubing. If it just started you may have picked up sediment inside the inlet valve most of which have a filter type screen inside. The valve would have to be removed and possibly cleaned. Some don't come apart and can only be replaced. The inlet valve is the plastic part on the back that the house water line connects to.
May 01, 2015 | Refrigerators
Gas thermostat fails
1) If your water heater plugs into outlet, then electronic gas controls are susceptible to power surge. and reversed outlet polarity, and undervoltage at outlet, lack of ground wire continuity between ground plug and manifold tube connected to bottom of gas control valve.
2) If sediment builds up inside tank, it will cover thermostat probe and cause probe to malfunction.
Tank can have sediment flakes build-up and still drain perfectly clean water.
3) There are 2 general types of Honeywell electronic gas controls valves installed on Whirlpool heaters.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The gas control for atmospheric water heater (passive vent at top of heater) is modular, and is not always removed from tank when replaced.
The other gas control for power vent models is removed completely.
4) Remove thermostat from tank to reveal 3/4" opening.
Look inside tank.
To remove sediment flakes: Tape assorted plastic pipes and tubes to shop vac hose and see if flakes can be removed. And remove drain valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
5) Check that air intake is clean using feather duster or compressed air, clean combustion parts as shown in product manual. If air intake is clogged with dust, then draft vent is slowed. This causes slowed venting of hot combustion by-product that will overheat combustion chamber.
Typically this condition will trip the FV system. BUT it might also trip the gas control thermostat.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Stand 3-legged water heaters on bricks so inspection and cleaning flame arrestor screen is ez.
Oct 30, 2012 | Water Heaters
My estate whirlpool washer model# taws800jq1 water wont shut off when you start cycle
See this tubing:
If this tubing gets sediment in it OR vibrates loose OR gets pinched from re-installing the cabinet OR if the tube gets a hole in it then the pressure won't build up as the water level rises and the water will not shut down. The component that tube is attached to it the water level switch. The likelihood of it being bad is slim. Most of the time sand and sediment gets into the tubing and simply blowing it out and reattaching the the tube to the switch fixes it. Be sure to pump out water after cleaning and re attaching the tube to the water level switch. Service manual and more
Nov 08, 2011 | Estate TAWS800JQ Top Load Washer
My water heater makes hoise what can i do to make it quiter
You posted under electric water heater.
1) Gas or electric, the noise is from sediment build-up inside tank.
Once sediment builds up, the only way to solve problem is to clean the tank out.
2) To restore full efficiency to electric water heater and stop the noise, clean the tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) To clean gas water heater is more difficult and less successful:
4) To prevent sediment problem, flush water heater each 6 months before sediment can build up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
5) Other things to know for water heater maintenance.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Mar 21, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Why does my water heater make crackling noises
The crackling noise is from build-up of sediment.
I forget exact reaction that causes the noise.
Water heaters exposed to hard water will create sediment inside the tank.
Following link shows sediment and remedies for gas and electric water heaters.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 25, 2011 | Reliance & 30 Gal LP Gas Water Heater
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 22, 2011 | Home
It won't fill with water
Water valve is locked out. a blockage in some sython tubes may be the cause .remove drain screen remove single screw on a domed plastic cover ,take out and clean the u shaped tubes(note the correct positions).take off the water inlet pipe to remove water pressure to valve (to unlock it) fit all the parts back and try it. if it wont work the blockage is beneath the tubes in a short tube(10" ) in the base below sython tubes.
Jul 15, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Sediment in hot water
With Rheem you have to back to the installer.Most of the heater have ten year warrany.
Mar 15, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Equator dishwasher portable
I think I know how to solve your problem. The pressure switch that controls the water supply valve can be accessed from the rear of the dishwasher. Take off the panel that is on the left, viewed from the rear. The pressure switch will be at the upper left with a two part tube leading down to the water sump area. Take the tube apart and clean it out. Any clog is most likely in the lower area, larger diameter tube. When you have the 'clamp' removed, you can pull the large tube off the reducer fitting. If the reducer fitting does not have any debris itself, you probably don't have to disassemble and clean out the upper part of the tube, but you could just to be sure. The first time I had this problem, I just blew out the lower tube. This time I really cleaned it out. To clean the lower part of the tube I used a doubled coat hanger wire. I straightened the tube and inserted the doubled wire, rotated it a few times, and pulled it out. It was covered with gunk. I actually repeated this process several times until it came out relatively clean. I reassembled the dishwasher and it is back to working fine.
Oct 03, 2008 | Equator 20 in. PLS602 Free-Standing...
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
