Question about Sharp Televison & Video
How to connect visio sound bar to sharp aquos
  • 17 Answers
SOURCE: My sound card on my sharp aquos 37 is shot. can i
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Posted on Aug 23, 2009
Testimonial: "Very helpful. Thanks for the information which might save me a lot of money if it works!"
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
  • 100 Answers
SOURCE: i connect desktop pc to
Is the connection HDMI?
  • Check your audio settings (control panel>sounds>playback) on your PC and make sure audio out via HDMI is enabled
I hope this helps
Posted on Mar 06, 2011
bugoy31
  • 1238 Answers
SOURCE: 60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Posted on Dec 19, 2011
How do i connect a LG sound bar to a sharp aquos
optical out of tv to sound bar. if not come of your cable box optical...
Sep 30, 2015 | LG Televison & Video
How do I connect a ubl sound bar to my 50inch actios TV
Are you wanting to physically connect it to the tv itself or are you interested in connecting the cables to it so you can use it for audio? Do you have a Sharp Aquos 50"? Many of these use HDMI cables to handle the audio. In this case you connect the HDMI cable to the UBL sound bar and the other end in the tv. Are you using an amp or stereo to handle multiple sources such as a Blu-ray player? In this case you audio source will go into the amplifier or stereo and then from there you will go to the sound bar.
Jan 02, 2015 | Televison & Video
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
Connect a Sharp TV to Sharp sound bar
Call a local custom audio/video installer that can help you for a small fee. It's okay to pay a professional and get the right help. It shouldn't cost you more than $50 at most, but probably half that amount since it's a very simple connection.
Here's a couple of weblinks that may be helpful...
http://hometheater.about.com/od/hometheaterglossary/g/Audio-Return-Channel-Arc.htm
http://www.sharpusa.com/ForHome/HomeEntertainment/SoundBar/Models/HTSB40.aspx
Dec 03, 2013 | Televison & Video
Disable speakers aquos
In the audio setup screen , direct the sound to external. If you're using an optical cable then direct the sound to optical
Feb 17, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
How can I connect my altec lansing speakers/bass to my sharp tv? I currently connected it via a wire that feeds from the altec lansing to the tv in the audio input. I am using HDTV and am trying to get...
Probably won't work. The audio amplifier in the TV isn't strong enough to connect external speakers. It would be best to use a sound bar using the optical connection.
Jun 17, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have just purchased a sharp HT-SB250 sound bar to go with my sharp 32" Aquos LED tv. The item came supplied with the RCA cable and having connected it to the sound bar and the audio connections in...
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
Jul 26, 2017 | Audio Players & Recorders
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
173 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
