Question about HP Compaq Presario SR2150NX PC Desktop
Compaq presario sr2020nx ethernet adapter issue
Hello. I have compaq presario sr2020nx, and connect to the internet using a dsl modem, via ethernet. I originally had XP as the OS, and recently upgraded to Vista, and now I cannot access the internet, in any way. It's acting as if the proper hardware is not installed for a local area connection, and I must connect to the web via LAC/LAN, and the only options I am getting when setting up a new connection are for dial up, broadband, or wireless. I am somewhat familiar with the technical hooplah and maybe you can assist me? Please and thank you.
  • Dan rogers
    Dan rogers May 11, 2010
    It sounds like vista may not have the drivers for your hardware. you are going to have to look up your LAN hardware and see if you can find a vista driver for it.
    Novelist:
  • 148 Answers
Since youre setting up a DSL connection choose Set up broadband connection > PPPoE. You will need the username and password you were given to this account (contact customer service at your ISP for this info). Enter the info and have it remember the password. Click connect. Once Vista finds the connection, it will ask you to choose a network type (Home, Work, or Public). Select the type and enjoy. If the connection fails, recheck your username and password entries.
Posted on Mar 04, 2009
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    My compaq presario V2000 will only connect to dialup
    To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
    Feb 15, 2010 | HP Compaq Presario V2000 Notebook
    Can't connect my Compaq SR2020NX to the internet
    Make sure the cat5 cable coming from the modem is going to the computer and bypass the router for now.
    If the computer is able to connect to the internet then you know its a configuration issue with the router. If it still can't connect to the internet then you know its an issue with the computer, might be a driver issue with the computer at that point.
    Call your Internet service provider and have them tell you the steps on how to configure your router to work with there internet service.
    Nov 30, 2009 | HP Compaq Presario SR2020NX PC Desktop
    Internet connection on compaq presario 2100
    If you have a DSL connection or Cable and hook up a new computer, you may have to reset the hardware (turn it off and on). If you have a Cable connection which you also use for a phone, you will have to also remove the battery from the modem to reset it.
    I am assuming that when you go into the device manager you see the network adapter and it doesn't have any caution symbol or an "x" on it to indicate a problem.
    You must also be sure you are not using an ethernet cable that is damaged.
    If you are trying to connect wirelessly, you must have a router that is properly configured and your wireless adapter must be enabled on your computer.
    Nov 23, 2009 | Compaq Presario 1700 Notebook
    Presario 900 laptop what internet dongle do i need to connect to internet.
    that completely depends on what kind of internet service you have.
    The laptop has a Ethernet connector so, if you have a internet connection in your home you should be able to connect it with a wire to the router or the modem and it should work.
    Sep 11, 2009 | HP 285527-001 - Compaq Presario...
    Ethernet port not working. can i connect from my dsl by using a usb cable instead.
    Yes, if your dsl modem is equipped with a usb option, you can hook it up to your computer but remember to remove the ethernet cord 1st. Both ethernet and usb cannot be connected at the same time. Once connected, your machine may search for a driver to install the modem via the usb port but it should work, especially if it's a westell. Best of luck.
    Greg
    Aug 05, 2009 | Compaq Presario 5000 PC Desktop
    Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
    If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
    Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
    Compaq presario c500..what do i need to buy or purchase to use the internet?
    This model has a wireless network adapter built in, so if you are on DSL isp connection you need a wireless DSL modem/router, if cable then a cable router to attach to your cable modem.
    Sep 11, 2008 | Compaq Armada 3500 Notebook
    Recently had a Belkin Wireless system install at home that keeps dropping the line in my room so want to use ASDL cable to connect to my computer what is the best modem card to get to do this
    Your ISP should provide you with an external modem that would be connected to your phone line, then you would connect the modem to one of the wired connections on the back of the router, or directly to the back of your computer.
    However, if you insist on an internal modem, I would suggest either a U.S. Robotics or Encore brand.
    Apr 20, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
    HP Compaq Presario SR2150NX PC Desktop Logo
    366 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
