Question about DeLonghi DDE50E Dehumidifier
Really thick ice on back of dehumidifier
I have had my dehumidifier for three years and never had this problem. I use it in the bottom level of my house and run it year round. I live in Louisville, KY so it generally runs the hardest in the summer months. This past week I went to empty it and the back was covered in ice. The temp downstairs has been the same the past 3 years - anywhere from 60-70 degrees. Why has it frozen up now? Can I use it again after I get all the ice off? The ice was inside the coils and the coils look to be somewhat rusted. It is not really possible to raise the temp downstairs or the rest of the house is too hot. I usually set the dehumidifier to 45%. Thanks for your help. Laura
  • 883 Answers
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Posted on Jun 24, 2007
What is causing ice build up on the coil bottom left? Whirlpool model AD50GEUSW dehumidifier?
Ice buildup is most often caused by low freon. Is the unit 10 years old or more? Might need a recharge. Turn it off and let it thaw then back on. If it ices up again, it likely needs a recharge.
Jul 09, 2017 | Whirlpool Dehumidifiers
GARDEN HOSE not bypassing the bucket for dehumidifier
Did you remove the plug from the United where the hose attaches? If so the end of the hose must be below the United as it is gravity flow. Hope this helps.
Aug 08, 2014 | Sunpentown SD-65E 65 Pint Dehumidfier with...
3 or 4 years old. the entire unit shuts of every 2 or three minutes. it stays off for a few seconds, then restarts
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
-0-0
Sep 11, 2011 | Friedrich D50C Dehumidifier
Coil frosts within 15 minutes in a warm room. After 1-2 hours they coils are covered with snow like frost 1 inch thick.
heatman101
Apr 30, 2011 | Goldstar DH304 Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
LG LHD45EL Dehumidifier Icing Over
The only thing you need to replace would be the temp control it sounds faulty hope this helps :).I had the same problem with mine and that is what went wrong.
May 16, 2009 | LG LHD45EL Dehumidifier
The dehumidifier is running but very little water is going into the tank. I cleaned the filter, long overdue, and it didn't help. Everything seems to be running well. I also have the room humidity level...
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
May 07, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier ices up on back - Why?
If this is dripping and making a water problem yep it needs some insulation on it as long as everything else is working OK. If it seems short of capacity and or not dehumidifying the problem may be short of refrigerant. You don't mention any of this so I'm thinking its OK and not a problem just how it works in your application.
Hope this helps Please rate me accordingly and good luck.
Mar 09, 2009 | Goldstar DH3010B Dehumidifier
Dehumidifier icecing up
Three possibilities for coils icing up.
1. Low ambient temperature in the area where dehumidifier is located. If so, shut down and de-ice it. Then move the unit to a different - (warmer) - location and start it up.
2. Heating element - (which cycles periodically to liquify frost on the coils and allow water to drain) - is malfunctioning.
3. Low refrigerant level in the unit.
Sep 25, 2008 | Eva-Dry EDV300 Dehumidifier
Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Sep 01, 2008 | Dehumidifiers
DeLonghi DDE50E Dehumidifier Logo
997 people viewed this question
Top DeLonghi Dehumidifiers Experts
Jim Goldsmith
Jim Goldsmith
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
