Question about Kodak 6800 Thermal Photo Printer
Kodak 6850 photo printer showing paper jam 91 or 93 when i press paper rewind button dan its shows paper empty
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
SOURCE: Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
  • 295 Answers
SOURCE: Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Posted on Oct 20, 2009
  • 103 Answers
SOURCE: psper jam in Kodak ESP all in one printer
try using the website www.kodak.com/go/itg
If still get the same paper jam error contact Kodak tech support.
Printer will be replaced if on the spot if bought from walmart for other stores you'll be asked to fax or email the proof of purchase.
Posted on Jan 26, 2010
How do I get into the diagnostic mode for the kodak 6850?
With printer off, press and hold "+" "-" and "menu" button at front panel. Then turn on your printer. keep holding the 3 buttons until you see "diagnostics" appearing on the lcd screen then let go of the buttons. you will be in diagnostic mode.
press the "menu" button once and you will see diagnostics. press "enter" button then "menu" button again until you see "check cutter"
Feb 19, 2015 | Kodak Photo Printer 6850 Thermal
I have kodak 6850 print,i replace head 3 years ago,now my printer make at funktion like blurry print,than it okey for some time,now it start again, and now it onley make blurry pics
Can we assume you have checked the printers settings ?
Ie set it to the highest resolution, set it to photo mode (as opposed to text), set the paper type to glossy .Still having Problem Then follow Us For
Kodak Printer Support
Mar 12, 2014 | Kodak Photo Printer 6850 Thermal
Screen is showing paper jam, software is showing error code 105-3515. Cartridge carrier won't move to center for checking seating of the cartridges. No paper found anywhere and I can't opt out to any...
Most printers have a hard reset method to restore factory settings and go through a diagnostic Power down then while powering up hold the power button while pressing another button (you'll have to look for a hard reset instructions)
Oct 15, 2013 | Kodak ESP 9 All-In-One InkJet Printer
I have problem in my 6850 kodak photo printer in dot and small thin line how to solve it
are you sure it's not something on your cameras lenses. My kodak piprinter actually told me I had something on my lenses
Jan 04, 2013 | Kodak Photo Printer 6850 Thermal
I have a Kodak ESP7 Printer that has paper jammed inside that there seems no way to get too. The Paper draw does not come right out.
Remove the paper tray. Turn the printer around with the back facing you. there should be two plastic tabs to press and open the rear paper port path of the printer. Open it and see if you can reach the jammed paper. If you cannot reach it from this area, unplug the printer from the power source, press and hold the power button for sixty seconds and turn it upside down. Shake it gently to see if the paper falls out (if it is a small piece ect.). If its not a small piece, plug the printer back in and when the jam error shows on the display click the "ok" or "accept" button. when you click that button - get ready to grab the paper quickly. Pressing the button causes the rollers to roll backwards and then forwards and reset the paper. It will roll the paper towards you and pause for a few brief seconds before pulling it back in again. that will be your change to remove it.
Oct 09, 2011 | Kodak ESP7 PP All-In-One Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak 6850 how do I print 4x6 on 6x8 paper without huge white border... now that you cant buy 4x6 media ?r
the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nov 22, 2010 | Kodak Photo Printer 6850 Thermal
Printer showing error as paper jam
This means the IR indicator is dirty with ink or something. You need to clean it.
I wish I could post pictures to show how to do this...
Feb 28, 2009 | Epson Stylus Photo R300 InkJet Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Kodak 6800 Thermal Photo Printer Logo
652 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
