Question about Dewalt D55168 1.8 HP Wheeled Portable Electric Workshop Compressor
Dewalt D55168 won't build pressure beyond 125 psi, motor runs continually
It has run perfectly for a year and a half. Started it up today and it won't build pressure beyond 125 psi. Checked for leaks and found none.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Worn ring and cylinder or bad valves maybe.
Posted on Jan 04, 2013
4 Suggested Answers
mxc2
  • 146 Answers
SOURCE: I have a dewalt D55168 air compresser. motor stays
Here is a parts diagram for the air compressor:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55168/D55168_PL.pdf
There are a couple of things to look for on the air compressor.
You will need to see if the piston ring is damaged or if you have a broken reed on the valve plate.
These are typically the two most common problems with this model.
Posted on Oct 13, 2010
  • 885 Answers
SOURCE: I have a D55168 Dewalt
Your concern is very well placed, at pressures that high a lot of damage can be caused by a failure. According to the manual for this model air compressor the approximate cut-in pressure is 160 psi and the approximate cut-out pressure is 200 psi. Meaning it should pump up to 'about' 200 psi and shut off and not come on again until it gets down to 'about' 160 psi. They say approximate and I say about because it's not an exact science setting the pressure switch. Spring rates are not always exact, pressure guages are not that precise, etc. When turned on, it should shut off at 200 psi +/- 10 lbs. If it goes more than 10 lbs over that (220psi), I'd recommend you get the pressure switch and or guages checked or replaced.
Posted on Jun 16, 2011
  • 142 Answers
SOURCE: Dewalt D55168 air compressor runs until 95 psi and
If you have no leaks the first thing I'd check is the ring and cylinder for wear. The cylinder wear is usually pretty obvious, but if you can see light around the piston ring it's bad. The replacement part number is N038785. Also check to make sure no valves on the valve plate part number A09819 are broken or bent.
Posted on Dec 16, 2011
2000 Dodge Status SE, runs for a bit then cuts off. Had a brake light that did not work with headlights on, changed bulb, a day out so later car shutters and dies. Get it started a couple times and manage...
Have the fuel pump pressure checked (sounds like the fuel pump is goiing out). The fuel pressure should be 46-50 psi on the 2.0L & 2.4L engines.
On the 2.0L SOHC engine fuel pressure should be from 44-55 psi.
Jul 29, 2014 | 2000 Dodge Stratus
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 05, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Lincoln mark 8 starts but won't stay running
Yeah... particularly the O2 sensors.. running rich ... weak
and intermittent...
Been there... Ultimately gave up a took mine to dealer.
After floundering around (and seeing I had already been EVERYWHERE they were looking) for two weeks...
They found one of the catalytic converters was collapsing blocking the exhaust... (jobbed it ou to a local muffler shop).
I have still never identified an elegant way to diagnose this issue...
Got to a point where it would not run...
At that point (had I known) I would have liked to try to remove the catalytic converter at the header to see if it would actually run
(CAN'T... one piece)
Liquid wrench, & ear plugs would figure prominently in this process...
ELSE
do look up you muffler & cat prices BEFORE going to an EXHAUST SHOP ($$$$)...
I figure I paid $1700 where a mere $700 would have been pricy
(installed... I bet you can do better).
1994 LINCOLN MARK VIII 4 6L V8 Catalytic Converter RockAuto
Carnac the Magnificent
Mar 01, 2017 | Lincoln Mark VIII Cars & Trucks
Dyna glo pro forced air heater won't ignite?
I've had mine for about 8 years now. Just started spitting out fuel and failing to ignite. Took it all apart and found a couple of cracked lines where they went on to the fittings. One was to the air pump and the other was a fuel line at the manifold. Cut them both back and reattached, but it still wouldn't ignite. Then I checked the pressure coming off the air pump and it was at 2 psi, should be at 3.4 on mine. Adjusted the fuel pressure up and bingo, it lit right up as soon as the pressure was right.
Jan 02, 2012 | Dyna-Glo Heating & Cooling
Hitachi Ec 119 compressor will not build pressure beyond 25 pounds; no air is heard leaking after I power down the machine. Is it likely the check valve or pressure switch?
If your compressor keeps running and only builds to 25psi, I would suspect the reed valves, head gaskets or a leak. With the compressor running spray soapy water on all fittings, around the head area and tank components. If no leak is found, remove the air filter and feel for suction at the intake(make sure head is not too hot). If you feel good suction at first then suction is lost after reaching 25 psi, most likely reeds or gaskets (with bad reed valves, sometimes you will actually feel air blowing out of the intake). Good luck
Oct 15, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The compressor starts to surge at 50 psi then blows the breaker took the air cleaner off and checked for obstructions none found .if i put my finger on the air inlet and restrict the intake by half it will...
Hi, my name is John. Welcome to FixYa. Clean your air filter, try running it with out it in place and see what happens, and let me know. Thanks for choosing FixYa....John
Dec 04, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Dewalt D55168 1.8 HP Wheeled Portable Electric Workshop Compressor Logo
375 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
