Question about InFocus IN24 Multimedia Projector
In Focus IN24 fan replace - InFocus IN24 Multimedia Projector
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
How do you reset the maintenance service indicator for infocus IN24
Have the projector fixed. The light will not go away until then.
Oct 24, 2010 | InFocus IN24 Multimedia Projector
Projector will not power off or display a picture
You have to double tap the power key to shut it down. The screen should go dark right away but the cooling fan will run for another 1-5 minutes.
Oct 19, 2010 | InFocus IN24 Multimedia Projector
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
InFocus IN24 powersupply part needed
chances are it's a capacitor, if it went on a power supply. get the power supply back and see if the main capacitor is puffy. you can fet one at almost any electronics store. otherwise, replace the whole power supply.
Nov 12, 2008 | Office Equipment & Supplies
InFocus IN24 Multimedia Projector Logo
29 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
