Question about Audio Technica AT-PL50 Turntable
No audio output
This unit has been stored inside my equipment cabinet for a few months, it worked fine when I put it in, but now acts like the output amp has quit. I've change cartridge / needle and tried switch the amp (switch under platter) with no change. I've tried plugging the output leads to 3 different amps, a desktop computer, a laptop computer, and into an audio amp for external speakers. I have tried different software packages, including Total Recorder and Audacity. Any suggestions or better yet a solution would be appreciated. Van
  • Van Cottom
    Van Cottom Jan 02, 2013
    Well, I dug out my O'scope, (Tektronix T935A) and started tear the turntable down. I found a "rotted" solder joint where the tone arm leads attach to the amplifier board. The assembly of this item was of extremely bad quality. Every time I would "touch" a wire it would break at the solder joint. Some of the boards are machine soldered, but there are many hand solder joints.
  • Van Cottom
    I think this item is a piece of cheap Chinese built throw away ****. And that is where it is going.
2 Suggested Answers
STYLUSCITY
  • 271 Answers
SOURCE: my turntable doesn't rotate any more...
Hi, the transformer that supplies power to the motor has been fried by the 220v input and will need to be replaced. If you remove it and go to your local electronic parts supplier they should be able to sell you a replacement. Cheers John styluscity.com
Posted on Dec 05, 2011
I have an RCA RTD3136 theater system, bought new in 2013. Worked fine for a few months, then started going out occasionally. I'd unplug the unit and reset, and it would work fine,for a while.
It sounds to me like the audio output transistor or IC is going bad,or the unit is overheating.Try blowing the unit out with canned air and relocating it so it can(breathe)<dissipate heat .
Nov 12, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
The support pillar at the clamshell end loosened. When I looked at it closely the plastic bracket that holds the pillar to the base is broken in half. Where can I get a replacement. (Not available on the...
The only way to get this part is from another broken unit.
If it were me, I'd try using an epoxy in combination with something to act as a splint, like a piece of Popsicle stick or a piece of metal, positioned inside the bracket. The bottom of the unit can be easily removed -8 screws, 4 under the feet.
I got my WMK300 at a local Goodwill store for $5. It worked fine for a few months before the temperature sensor fuse needed to be replaced ($2/4 at eBay).
Feb 23, 2014 | Waring WMK300 Professional Belgian Waffle...
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
Have Onkyo TX-NR808 receiver. Not quite 3 months old. Unit shut down when volume was turned up, but not drastic. Tried to adjust the db levels of my front speakers, in particular the center channel. As I...
The problem is the audio output ic's, one or more channels has developed a short causing the safety shutdown to engage. The only solution is take it back where it was purchased and since it is under warranty it should be repaired free of charge if not a possible exchange.
Jan 09, 2011 | Onkyo TXNR808 Receiver
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
No audio output from a Uniden Bearcat BC-100XL Scanner
does the speaker have static when you open the squelch?
Mar 27, 2009 | Uniden Radio Communications
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Audio Technica AT-PL50 Turntable Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
