Question about Microwave Ovens
Sharp R395 Microwave.. cant set clock.
After disconnecting the oven from the powerpoint to move it, when plugged back in you cant set the clock as per instructions. The oven still works but only if I press the reheat button. The start button does not operate.
    Genius:
  • Microwave Ovens Master
  • 1,669 Answers
Sounds likein the moving you loostened wires in the front panel or flexed the circuit board inside. You will need to open the control panel and inspect it. It could also be just some dirt or dust getting on the controls....blow it out with clean dry compressed air!
Posted on Dec 31, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
SOURCE: Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Posted on Dec 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-510AK Microwave Oven Fuse Blows
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: sylvania microwave
They have that manual their site, but it's only in French!
If you don't speak French, then visit the manual download page and put in only "SM807" in the search box.
The manual for either the SM80703 or SM80704 may be close enough to yours to work.
You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My sharp R1870 microwave/convestion oven turns
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 28, 2010
Testimonial: "Wow, this person knows his stuff! Great advice. Thanks!!"
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
Clock reads 88:88, won't turn on
Try disconnecting the power completely and waiting about 5 minutes. Plug it back in and see if you can set the time.
Jan 14, 2010 | Sharp R-1480 Microwave Oven
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Don't know how to set clock on it! Still working well, however.
http://www.usersmanualguide.com/sharp/microwave/r-242m
Theres your manual...
click Download
R-242M pdf user manual
Then either click view or download...
Apr 24, 2009 | Sharp R-242 Microwave Oven
Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
Aug 06, 2008 | Sharp R-254 Microwave Oven
The door on my Sharp Carousel II Microwave Oven will not open. The display says LOCK. Looking at my booklet revealed that there is a safety lock feature. I tried to cancel by touching Autostart/clock,...
Sounds like a drawer type microwave or a combo oven and microwave?
If your manual's instructions didn't fix it, you can try a hard reset.
Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you still need help, please reply back with your model number so we can help you.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Sharp Microwave Ovens
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
