Question about MPC Computers ClientPro 414 All-In-One PC Desktop
Does my clientpro 414 support windows 8?
I would like to know if my Clientpro 414 can hold/support windows 8
  • MPC Computers Master
  • 27,725 Answers
You might be better of getting a newer computer to run windows 8 to get the maximum benefits from it.
Your computer probably has xp on it and although being the benchmark of windows is probably outdated
You must have at least 1GB (DDR) RAM module to run Windows 8 efficiently.
http://windows8qa.com/439/what-other-hardware-are-required-to-install-windows-8
Posted on Dec 31, 2012
  • 44 Answers
SOURCE: Get My Drivers
The company that built the ClientPro 414 for MPC sold it to several other companies. It is also known as the Mecer Multimedia PC L19IA.
Here are the XP drivers directly from Mecer:
http://downloadcenter.mustek.co.za/list.php?dir=Repository%2FMultimedia+PC%2FL19IA%2FXP%2F
Posted on Jul 01, 2009
msnseb
  • 88 Answers
SOURCE: How to replace ram in clientPro 414
Back of computer near where keyboard and mouse plug in. Take panel off back, they are just below cooling fans! Please rate me!
Posted on Jul 06, 2009
twitchyguy
  • 12 Answers
SOURCE: I have an MPC Clientpro 414, in 07 I replaced the power supply.
This is most likley a overheating problem. I work for a company who uses 2 of theese computers for each of our almost 600 stores. As one of the facility support guys, I have seen this time after time. What I do is to remove all the access panels from the back of the computer as well as the HDD and optical drive (they both should slide out easily after removing 1 screw each) and blow the entire thing out with a whole can of air. I also remove the HDD from it's sled and blow it off to keep it cool. Put everything back together and you will be good to go again, at least until the backlight inverter burns out. Good luck!
Posted on Jan 11, 2010
  • 106 Answers
SOURCE: I NEED A SERVICE/OWNER MANUAL FOR A MPC CLIENTPRO
Try following link, looks executive file but after installation it puts up a shortcut to manual on desktop
http://www.mpcdrivers.com/sylvia/Support/Desktop/MANUALS/EMA/EMA001054-01%20Install.EXE
Also, can download from
http://www.mpcdrivers.com/apps/compdet1658.html?ID=11342
Hope this helps..!
Posted on May 20, 2010
  • 44 Answers
SOURCE: where is the battery in an MPC ClientPro 414? How
The battery is fairly easy to replace on a CP414, but you need to be careful to avoid breaking the battery socket.
You will need a small Philips-head screw driver (#1, I think) and a small flat-blade screwdriver (for prying). A pair of tweezers will help too.
1. On the back of the system, remove the cable door. It is held in by 1 screw and wraps around the back/bottom of the system.
2. The battery is half-way under the optical drive. The only way to easily remove it is to remove the optical drive.
3. Remove the optical drive. It is held in by 1 screw near the bottom of the system (not the screw in the bottom-right corner of the back of the system, but the one just above that). With the screw removed you can push on the back of the optical drive by reaching in through the cable door you removed in step 1.
4. The battery has a sticker on it that protects it from shorting against the optical drive. This sticker is important, so save it if you can. If you can't save it, use some electrical tape or similar to prevent a short.
5. Peel back the end of the sticker that is closest to the optical drive frame and gently pry back the metal clip that holds the CMOS battery down. It should pop out fairly easily.
When you re-insert a new CMOS battery, make sure you insert the end under the metal clip first and then push down. Also, make sure it is properly aligned or you will probably break the battery socket.
Replacing the battery is much easier if the motherboard is removed first, but removing the motherboard adds about an hour to the whole process. If you want to go down that route, let me know and I'll give you some help.
--Russel
Posted on Oct 17, 2010
How much is clientpro 414 worth?
If this machine is running XP, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine.
Good luck.
Jun 29, 2014 | MPC Computers ClientPro 414 All-In-One PC...
Clientpro 414 won't read a dvd with an iso file.
Judging by this review, your computer possesses a CD drive and NOT a DVD drive.
http://www.cnet.com/products/mpc-clientpro-414-all-in-one/specs/
Your best luck at installing Linux (Good choice for an old computer by the way) would be to use a USB Drive for the installation.
You should find the instructions for creating a USB Drive and for booting from live USB on the website of the Linux distribution you're trying to install.
Apr 26, 2014 | MPC Computers ClientPro 414 All-In-One PC...
Pins in power adaptor will not insert into place where adapter is to plug in
HI
The port of the power adapter for your MPC Computers ClientPro 414 All-In-One PC MUST be the same below
Dec 07, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Where can i get a network driver for a clientpro 414
http://www.mpcdrivers.com/sylvia/Support/Desktop/mboards/AIU001000/Win2k/AIU001000_2K_LAN_7-80-0-0.exe
downlaod this ur LAN drivers
Jan 15, 2010 | MPC Computers ClientPro 414 All-In-One PC...
ClientPro 414 Parts Source
I have many spare parts and memory for ClientPro 414. Please contact me for more info.
Apr 08, 2009 | MPC Computers ClientPro 414 All-In-One PC...
MPC Computers ClientPro 414 All-In-One PC Desktop Logo
101 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
T-Comtech Repairs
T-Comtech Repairs
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
