When weather warms up or dries up - it starts and runs perfect. Sprayed ether in tb and still wouldnt start. replaced ign coil but same problem
SOURCE: 1998 dodge neon turns over but wont start
your crank sensor it is located on the back of your engine block behind the alternator check it see if it is bad
SOURCE: 2003 Dodge Ram 3500 Diesel hot and cold start issues without plug
your glow plugs not working or glow plug relay or controller not working.
Replaced coil and all is good. Starts in rain, snow or cold weather now!
The ignition coil is the most likely cause. My 94 Dodge Dakota had the same problem. Cheap and simple fix.
