Question about Samsung SC-D107 Mini DV Digital Camcorder
Cassette will NOT automatically insert into scd107
We put mini DV cassette into its receptacle and close it gently; the cassette will NOT automatically cycle DOWN into the scd107.
3 Suggested Answers
SOURCE: Cassette tape
mycomputer cannot see the camera in usb
Posted on Aug 31, 2008
caroldon
  • 17129 Answers
SOURCE: I have a Samsung SD263.
There is a fault in the loading mechanism that has resulted in the mechanism being out of alignment or failed.
If you hear any motor noise as you switch on the camcorder then the problem is related to failure of link of the loading mechanism , can be a gear , belt or pulley that has slipped off.
However if you do not hear any noise then the possibility of failure of the motor drive, driver circuit- loading IC- or the motor. Now this needs a technical check of the voltages to the circuit to confirm and you must be versed with basic electronics and some mechanical skills, so as to remove carefully the panel , boards and check the mechanism.
In fact it is no as easy as mentioned above but the work needs good attention and skill to infer.
Posted on Feb 23, 2011
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Jan 10, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Samsung SC-D107 Mini DV Digital Camcorder Logo
26 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
