Question about MPI USB 2.0 to HDMI DVI VGA Video Converter Display Adaptor w/Audio
My nexxtech usb to hdmi adapter will not recoginize my TV, what am I doing wrong?
I have followed the instructions for set up, and previously it had worked, but now does not want to recognize my TV
How to hook up android box to smart tv
You need to go to Radio Shack or Look up online; but buy a Auvio USB/HDMI PC to TV adapter and an HDMI cable at 6 to 12 feet long. Hook it up following the instructions in the kit or watch the video on youtube.com to hook it up. You can hook up your phone or computer using this adapter. Have fun watching your videos then.
May 24, 2017 | Televison & Video
Can I connect my fire hd 10 to my tv using a cable.
It seems as if it is possible to connect your Fire HD 10 to a TV via a HDMI cable. In order to do this you will either need:
  • Amazon HDMI adapter for fire tablets
  • Micro HDMI/ USB to HDMI cable
Here is a helpful article with ways to connect to a TV and links to the types of adapters on amazon.
How to Connect Kindle Fire to TV
Amazon com Amazon HDMI Adapter for Fire Tablets 4th Generation Kindle Store
Amazon com AmazonBasics High Speed Micro HDMI to HDMI Cable 3 Feet Latest...
Apr 02, 2016 | Amazon Kindle Fire HD
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: http://www.mhlconsortium.org/devices.aspx . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
Jan 25, 2015 | Acer Iconia A1-830 Tablet - 16GB
How do i connect sony mobile phone to sony tv
Watch and listen to your Xperia TM content on your TV
Open this link & watch this video will let u know how to connect sony mobile to bravia via mirroring.
Thank You
Dec 01, 2014 | Sony Cell Phones
How do i get an onn electronics android plug to hdmi adapter to work? It came with no instructions and i have tried multiple phones and hdmi cables. Plz help....
Connect one end of the HDMI Lead to the adapter. Connect other end to the HDMI on the TV. Connect the adapter to the charger with the usb socket on adapter and connect the adapter to your mobile . Make sure you plug it in to an electric soocket or it wont work . I have one myself for the Samsung Galaxy S3 and mine works just fine . But you have to get the right adapter for your phone
Nov 21, 2014 | Televison & Video
No icons showing with nexxtech hdmi adapter
re-install the drivers after uninstalling the previouss drivers.
Jul 13, 2014 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Need help with Nexxtech usb to hdmi adapter model 1511217 manufactures number AN2800D2
None of the six previous "suggested solutions" have ANYTHING to do with "Nexxtech usb to hdmi adapter model 1511217". WTF????
Call The Source (aka Radio Shack Canada). Sorry I don't have their number.....but, Google it. It's toll-free, in Barrie, Ontario.
Sep 10, 2012 | NexxTech Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
USB 2.0 cardbus pc card adapter N2PUCB
Straight from NexxTech's website:
http://download.nexxtech.com/nexxtech/N2PUCB_pcmcia_USB2.0.zip
Jan 05, 2008 | NexxTech NCARDBUS Network Adapter
MPI USB 2.0 to HDMI DVI VGA Video Converter Display Adaptor w/Audio Logo
59 people viewed this question
Top MPI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MPI Audio Player and Recorder Expert? Answer questions, earn points and help others
