Question about Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket
How to calibrei the vertical bean
The vertical bean is 3/16 out of place
I need instructions on how to download to my kindle, from Calibrei
It's Calibre and it should recognize the Kindle when you plug it in using the USB cable that came with the kindle. The top menu will change and show the device.
May 25, 2015 | Amazon Kindle Wireless Reading Device
I need a description for how to open and clean the grinder. I keep getting fill beans message and it has beans.
I have not done it, but I believe you simply remove the two screws you can seen when you look into the coffee bin.
I used to get "fill beans" messages when there were beans in the hopper. Eventually I determined this was due to my choice of beans: oily (ie. shiny) beans seem to clog up frequently, "dry" beans (beams without a sheen) rarely clog up.
Since the beans are gravity fed, oily ones tend to stick to one another
May 01, 2015 | Jura Capresso Impressa S9 Coffee...
How do I cook pinto beans in a roaster oven?
Soak beans overnight in cold water, drain and rinse, place in roaster (adding a ham bone is a good seasoner), add salt (about 3/4 Tablespoon), cover with water, turn roaster on to 350 degrees, add hot liquid or ham juice when beans are going dry and stir. Don't check too often, because it will release heat and slow cooking time down. Takes 5 hours to fully cook. (Note: bean pkg has quick soak method which works in place of the overnigt soak)
May 07, 2014 | Rival 18 Qt Roaster Oven with Buffet...
How do I clean my burr mill (Models BM1 and BM3)?
Always unplug your burr mill after use and before cleaning.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Sep 02, 2011 | Bunn NHB Coffee Maker
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket Logo
42 people viewed this question
Top Pacific International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
