Question about Maytag Dishwashers
How do you remove a maytag dishwasher spray arm on MDC4000AWE
eagle338
  • 4889 Answers
SOURCE: Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Posted on Oct 19, 2007
vest6
  • 196 Answers
SOURCE: How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
Posted on Jan 10, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 423 Answers
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Posted on Apr 01, 2009
fluxchrizm
SOURCE: Maytag dishwasher with a spray arm that is stopped
We have a dwu7400 so i'm not sure it is the same, but above the top arm you should see a serrated ring (looks a bit like a flower petal) and that should spin off and the arm should come with it. There's a snap that holds those pieces together that if you squeeze it with your fingers you can get it out. Just reverse that to put it back together.
Posted on Nov 08, 2009
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
How do you remove the bottom spray arm?
Hello
Unplug the dishwasher. If you cannot access the plug, turn off the dishwasher's circuit breaker in the electrical circuit breaker box to stop electrical power to the dishwasher.
Open the dishwasher's door, and pull out the bottom dish rack. Set it aside.
Hold the lower spray arm still with one hand. Turn the retaining nut clockwise with the other hand until it comes free. Pull the spray arm up and off the shaft.
Sep 12, 2011 | Maytag Dishwasher
Dishwasher makes grinding noise when you turn it on
There is something in the shredder plate under the spray arm. To clear this you will need to remove lower spray arm and then using torx driver remove the screws holding the housing together and remove the housing to get to the debris underneath. Good luck and hope this helps.
Mar 03, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
I have a Maytag MDB9100A leaving food particles
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
Jul 23, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
User manual
where can I find reciever end that attaches to faucet for maytag freestanding dishwasher ?
model # mdc4000awe , serial #17412568uu
Aug 29, 2008 | Maytag 24 in. MDC5100A Free-standing...
Maytag Quiet Servies 100
Yes remove the arm ,if its the lower arm it un screws,the upper arm snaps on& off.
Jun 03, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
