Question about Shoprider Dasher 9 GK73
No speed after Battery Change
I just replaced the batteries in my shoprider Dash 9. When I took it out, I have about 2 miles an hour in forawrd, and barely no reverse. After 2 hours use, the batteries show 3/4 full. And ideas?
  • alanwms
    alanwms Dec 31, 2012
    The H bridge is part of the drive electronics. It is the section that controls the power to the motor. You most likely need to replace the whole drive. If you have experience in replacing transistors or know of someone, you could replace them..
    Problem Solver:
  • 8 Answers
The "H" bridge in the drive electronics is bad. Need to replace the drive. Your old battery is probably good - To test my idea, run it at your "low" speed then check the battery temperature with your hand. Is it hot/warm? if yes, then the battery has been working very hard due to the "H" bridge being bad and taking current
Posted on Dec 31, 2012
Testimonial: "Thanks. "
  • Arthur P Mencher Dec 31, 2012
    Where would I find the H bridge?
4 Suggested Answers
  • 346 Answers
SOURCE: Shoprider Scooter Hero is very slow to backup or
Please visit:www.alldatasheet.com its free Colin.
Posted on Feb 07, 2011
  • 21 Answers
SOURCE: Shoprider scooter what it does is that runs for
i have the same problem with my pride hurricane ,
i am looking into the throttle potentiometer to see if that is the
problem,
i will post on here if i find out,
let me know how you get on !
Posted on Dec 13, 2009
  • 26 Answers
SOURCE: i need a battery for a shoprider hero scooter.
phone 0208 676 0944 ted
Posted on Apr 15, 2010
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
My Battery on my Shoprider Delux is fully charged but lasts only about 45mins is my Battery Knackered?
first of all , this is a common mistake , can you borrow another charger to make sure that is not causing the problem , you need to convince yourself that the charger is okay then lok at the batteries located under the cover located under the seat, make sure the batterys connectors are clean and tight, if all fails sadly it is a batteries replacement.
Nov 21, 2012 | Shoprider Sprinter Deluxe Four Wheel...
Left chair unplug without charging battries are down and put charger on for 1 1/2 hours nothing has happened what do we do?
Hi,im disabled myself.when it comes to batteries,they gotta be treated as manufacturer says,please let the charger charge the batteries for the time given.Then go from there.I have a shoprider milan scooter.& even if i go 1/2 a mile i put them on charge so they are fully charged,my batteries are the Gel kind.But please read all info on Batteries.You can visit:shoprider.com & see what info you can download as a PDF File,print & keep for future ref,Colin.
Aug 01, 2010 | Jet 3 Ultra Power Chair
Shoprider scooter what it does is that runs for about 1hr. or 11/2 and make a sudden stop and started beeping and it doesn't move. I turn off the key and wait for about 1 min. and turn on the key and start...
problem,
Nov 02, 2009 | Shoprider Sprinter Jumbo 3
No power to accelerate after replacing battery
if the battery was dead for at least a hour, the computers are resetting its self, try to drive it slow about to 30mph for a couple days computers will change the way transmission shifts and how the rpms act.
Oct 26, 2009 | 2004 Saab 9-3
1997 s-10 sames to get vapor lock. after filling up with gas,drove truck home (4miles} left sitting in drive way (hot sun) tried to start 4:pm. 9:pm 9:am removed gas cap started up first time. Aprox....
Change your fuel filter, it may have gone it's life time and is getting to dirty to let fuel flow properly. Your fuel pump to may be getting weak, if the fuel filter is dirty the pump works harder and heats up and could be over heating the fuel pump relay too. The fuel pump relay i believe is in the glove box behind a panel that say relay, there should be (3) in there and the middle one is the fuel pump's. switch then around after you change the fuel filter and if you get a chance, check your fuel pressure at the shredder valve. Good luck and hope this help's if there is a Auto Zone around you, you can ask to use the fuel pressure gauge to see what fuel pressure you have and they'll have the step by step instructions on how to do it and takes about 5 min to do and will have the fuel filter and step by step to replace that too. Keep me posted, be glad to help.
Jun 08, 2009 | 1997 Chevrolet S-10 Pickup
Speed-o-meter and RPM gauge do not work
if the engine is running fine and no limp mode no engine lights. abs is working then the only other thing could be the dash may need replacing as putting the battery on wrong can blow the electronics in the dash as they are both linked. i ask is there any other problems as the rev counter work to ecu in line with speedo and the abs unit to determine timing etc. speedo works of the abs system the connection between them both is the board in the dash board. you can replace the boards in the dash but you will need replacement dash parts to do this but remember if you change the dash you need to log the miles as new dash will have different miles and uk mot log your miles to dvla. USA i dont know you would need to look into this.
Jun 29, 2017 | 1996 Audi A4
Shoprider Dasher 9 GK73 Logo
88 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
