Question about Danby Dishwashers
I've hooked up my danby to the faucet but the water leaks out the top how do i fix this?
I got this dishwasher for xmas and put it together but the connector piece that i've hooked up to the faucet leaks from the top[ when i turn on the water and nothing goes into the machine do we need teflon tape?
  • Danby Master
  • 17,129 Answers
You need to have the RIGHT couplings so that the inlet is secured correctly to maintain the right water pressure to the washer. A visit to the hardware shop, plumbing section could help a lot to get the right choice of coupling to mate the hose from the outlet to the machine. You can use teflon if the thread is too loose and makes a leak.
Posted on Dec 31, 2012
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
Danby washing macine is leaking
Hi There,
I have just spoken to a technician here at Danby and he suggested to replace the washer in the hose.
If that doesn't work, please feel free to contact our customer service department at 1-800-26-DANBY (1-800-263-2629)
Jun 19, 2012 | Danby DWM99W Top Load Washer
The cold water on my Delta double hand faucet is leaking. I replaced the spring and rubber seat. when I put it back together, i can not turn the water off with the handle. I took the stem assembly out...
I believe they go in one way ,, but I've seen some that are 180 degrees out, which would make it so the water won't shut off, also with delta and moen,, add some plumbers grease to the o rings and faucet washers, so they don't stick when replacing,
Sep 28, 2011 | Delta & Stem Unit Assembly
How to hook up detached dishwasher to faucet?
Hello there:
you are going to want to make sure that the threads on the hose match the faucet and also make sure that the gasket is in place you might even need to get a adapter for the unit to hook up to the faucet.
i would consult the manufacture or the users guide for further help
Aug 08, 2009 | Danby DDW1805W Designer Series...
Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Jun 02, 2009 | Danby DDW1805W Designer Series...
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Faucet connection
You only need to put back on the steel clamp that fits over the assembly which holds down the shield, the spring, and keeps the 4 ball bearings in place. The ball bearings may be tricky though as they tend to fall out when your putting the assembly back together.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Danby DKC645BLS Kegerator
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby rolling dishwasher -- i've hooked the connector up to the faucet turned on the water and it starts leaking out the top of the connector -- like the water doesn't have anywhere to go. is this normal?
you are right in that the water has nowhere to go initially, the water will be taken by the dishwasher when it wants it, not all of the time (or alot of water would be wasted.)
it sounds like you do not have a good seal is the tap connector if it is leaking like that, check the rubber ring in the connector and ensure that there is not a build up on limescale on the tap (which can make for a leaky seal as the surface is uneaven)
Apr 10, 2008 | Dishwashers
Connector hose
the water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Jan 30, 2008 | Danby DDW1805W Designer Series...
Dishwashers Logo
138 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
