Question about Acer Aspire X3200 PC Desktop
Sd card reader not reading on acer X3200
Sd card reader wont read card
  • 16 Answers
SOURCE: How does the 5 in
There should be 5 slots. Near each slot has the trademark of the card that the slot is for. If you are unable to identify the trademarks or there aren't any ways of finding which slot is which, then try each slot. Do not force your SD card into the slot. There should be only one slot that is the perfect fit for the SD card. Just slightly change the angle of the SD card until it slides in. The SD card has little to no extra room so it will take a little while to get the SD card in. Also the slot is spring loaded so you should here a click when it is in correctly.
If you have trouble, just keep trying and don't force it in. Trust me that it will fit if it is the right slot. Sometimes I get my SD card into my Wii or laptop in under a minute and sometime I have to mess with it for over 5 minutes (the angle of the stand for the Wii doesn't help at all).
Once you get the SD card in correctly, it will show up as a drive in "My Computer" but Windows XP and Vista have normal alerts with a "new hardware found" tone. Think of it as an USB flash drive that is smaller and goes into a specific slot.
When you are done, just push the SD card in and the slot should eject the card so you can pull it out.
Good luck and I hope you get it in.
Posted on Aug 15, 2008
  • 121 Answers
SOURCE: card reader can't read 4GB SD card
Your card reader probably cant read HC cards. Any of the newer cards 4GB and above is considered HC: High Capacity and only the newer card readers can read that. Same thing goes with older cameras. 2GB would be the max for older cameras that dont support HC and card readers that dont support it.
Posted on Dec 16, 2008
  • 58 Answers
SOURCE: acer 5920 does not work with sandisc 1gb memory card
Your Minolta camera uses file format, which is not recognized by PC and vice verse. When you insert, PC can't read it, and asks to format. But when it is formatted for PC, your camera can't read it. Try to format it in camera, if it's not possible, then get a new memory card and use USB cable to copy images.
Posted on Feb 15, 2009
  • 13433 Answers
SOURCE: I can not get my acer aspire m5641 to read my
the drivers for the sd card reader are probably not installed if its a build in reader, if its a usb reader it shouldn't need any drivers.
http://support.acer-euro.com/drivers/downloads.html
Posted on Jun 11, 2009
SOURCE: Acer aspire integral SD card reader
install the proper dirver by opendriver.com and enjoy. raheelahmadkasuri@gmail.com
Posted on Jul 12, 2009
It says I have a damaged sd card and wont read it
Remove the card, and gently clean the card reader slot! If dust or particles get on connectors then it will mes with the reading!
Jul 14, 2017 | LG Phoenix
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
My Acer 3692WLMi does not read my Fuji 8 gig SDHC card but it will read my Panasonic 2 gig SD card. Can someone give me an answer/solution. Thanks C
While I'm not directly familiar with this Acer model, it looks to be an older laptop. It's almost certain that it was built prior to the SDHC cards being created - a lot of older memory card readers are not able to read the High Capacity (HC) flash cards. I actually own a couple of devices that also would not read the 8GB card.
To test, I would recommend finding a newer USB SD card reader that you could either borrow or purchase (they're usually not too expensive) to see if that reader could get the information from the SDHC card.
If that works, the problem would be that your flash card reader does not support the higher volume cards. This is the most likely possibility.
If it doesn't work, there may be an actual problem with the SDHC card itself.
Hope this is helpful!
May 13, 2011 | Computers & Internet
Camera reads communication error when trying to upload photos what might be the prob
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC.
I BET THE ONE CARD THAT DOESNT READ IS AN HC. THIS IS ALSO TRUE WITH OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER.
I JUST HAPPENED TO PUT AN OLDER SD CARD IN MY NEW POWERSHOT SD1300 AND IT READS FINE, ALL NEW CARDS SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
Aug 24, 2010 | Canon PowerShot SX120 IS Digital Camera
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
My acer can read an sd card,How can I get it to
While the spec sheet does not say SDHC specifically I am surprised it does not read and write it since it is an up to date unit but if it wont you can get an inexpensive USB 2.0 reader and it will work. I would check and make sure that the SDHC card is formatted properly if it is go with the adaptor. Good Luck
Jul 27, 2009 | Acer Aspire 5720-6661 Notebook PC
I can not get my acer aspire m5641 to read my media SD card
Jun 11, 2009 | Acer Aspire RC500 PC Desktop
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
Card reader can't read 4GB SD card, smaller one's (2GB)he can read
Dec 16, 2008 | Acer Aspireā„¢ T180 PC Desktop
Acer Aspire X3200  PC Desktop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
