Question about Cobra 19 DX IV CB Radio
Need a schematic for a Cobra 19DX IV
Trying to increase watts and modulation, getting different opinions Cut D9 the other said cut Dm1 any help would be appreciated
    Genius:
  • Cobra Master
  • 1,795 Answers
Don't cut or increase watts.Check it out first as you may want to turn down wattage. Cutting or clipping a radio is not good . over modulation could cause a problem not only with the radio but with those you talk with. You will be slashing your modulation waves over the whole band any if it interfears with them they won't be happy. you can get all the information you want on www.cbtricks.com
Posted on Nov 04, 2013
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
Communicomm
  • 90 Answers
SOURCE: cobra ltd classic no modulation
Assuming that you've tried another mike, the problem may lie in the speech amplifier circuit within the radio, something that will require someone with technical knowledge to repair.
Posted on Sep 26, 2008
  • 40 Answers
SOURCE: PEEK IT
not a good idea to do it yourself you need the proper equipment to do the alignment you must know what part is the transmit and what is the recieve.
Posted on May 10, 2009
Benimur
  • 6966 Answers
SOURCE: cb problem have a cobra 19dx iv with a 2ft magnet
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
  • IC1 - KIA7217AP audio IC;
  • CM 10 & 15 - audio output capacitors 470uF / 16V.
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
Posted on Aug 01, 2009
  • 1274 Answers
SOURCE: I know to simpley clip
Hello skeeterstoke,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
You didn't state what 29 you have! Here is one for the OLD 29, cut
D24, and adjust L7, and L8 for highest peek on the watt meter. If this is not your make, please re-post
with the one you have! Your comments and testimony's are always welcome here at FixYa.
Thanks for choosing us today and in the future.
John
Posted on Mar 26, 2011
How do I adjust modulation on cobra 25 wx nw st?
The Modulation adjustment is VR5, or you can cut D9, though I do not recommend completely disabling the AMC circuit. If VR5 does not have enough range, lift the banded end of D9 & solder a 1K-ohm resistor in series with the diode, then adjust for 100% modulation or to where the AMC circuit just starts to limit modulation.
Mar 09, 2014 | Cobra 25 WX NW ST CLASSIC CB RADIO WITH...
Finals for Cobra 19DX IV...where can i buy them?
cost of finals plus S&H plus labor. cheaper to buy a new one and have that one for parts. H&Y electronics has them but you have to call them to make sure they do.
Aug 22, 2013 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
Which pod controls wattage output on Cobra Ultra 19 3
L-21,L-22,and L-17 on a scope for 4 watts max output.
Jan 23, 2013 | Cobra 19 Ultra II CB Radio
Cobra 19dx iv eu when you key the mic no power band no modulation
did you take the protective plastic off the meter front. could be a number of reasons.
Feb 05, 2012 | Cobra Radio Communications
Cobra 19dx iv when i key up it swings all the way to a 9 is there any way to set swr,s without a meter
Just buy a factory built antenna/(it should be close) Buy you a magnet mount RADIO SHACK job(works). If your indoors buy ANTRON A99(set at 1.3 SWR factory). If it keys 9 db then that equals 4 watts output thats OK.
Apr 02, 2011 | Cobra 19 DX IV CB Radio
I know to simpley clip the modjulation on a cobra 25 you cut D9 what do you cut on a cobra 29 to do the same
Hello skeeterstoke,
Welcome to FixYa.
John
Mar 26, 2011 | Cobra 29 LTD CB Radio
Can a 19 ultra power be turned down to 1 watt? If so where?
Yes it can, but it requires the addition of some components. It isn't really a straight forward install. It needs some reworking. In my opinion, not worth the trouble.
Sounds like you want to run a linear amplifier. If you really want to run an amp, get a better radio to do it. There really is no other reason to lower the dead key that low. Also, 1 watt might be too low. May not drive the amp well.
If you just want to make the radio swing, 1 watt is way way too low. You will have barely any carrier and the radio will sound like ****. That radio stock dead keys 2.5 watts. That's perfect for swing. Now you just need to have more modulation. Find DM1 and unsolder 1 leg and pull it out of the board. Now you will have full modulation. You will deadkey 2.5 and swing to about 15 watts.
If you want to run an amp, get a good radio. If you like cobra, get a cobra 29. They are fairly cheap, and sound amazing. As well it is real easy to lower the dead key in that radio.
Nov 12, 2010 | Cobra 19 Ultra II CB Radio
Cobra 29 Ltd
  • remove TR18;
Sep 07, 2008 | Cobra 29 LTD CB Radio
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Sep 06, 2008 | Cobra 29 LTD CB Radio
Question about my cobra 200
no need to increase power output. you can take a radio with 100 watts and a radio with 10 watts that had had a modulation kit installed and the 10 watt radio will out talk the 100 watt radio ALL day long. the best thing to do would to put a mod kit in it and have the dead key cut back to 1/2 watt then put as little amp behind it. with those mods it will be loud and clear. hope that helps
Dec 30, 2007 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
139 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
