Question about HP G60-235DX Notebook
CD will not read
Cd will load but will not be reconised by computer, The cd sounds like it is trying to run, the disc is spinning.
  • John Hagen Jan 02, 2013
    I have cleaned the optics and reloaded firmware, I think the CD is faulty and will need to be replaced.
  • 3 Answers
Clean it with mild soap and dry with a soft cloth. Rub the soap in gently with your fingers after a good rinse. Make sure there is no grit on the surface. If you feel anything but a glass-smooth texture under your fingers, rinse more and try again. Wipe out from the center very gently, do not wipe in a circular motion.
Posted on Dec 31, 2012
MAD ICE
  • 52 Answers
SOURCE: ok....my cd-rom drive is not reading the cd's?
first remove the cd and restart the computer and see if the E:driver if it is not let me know if it is there put the cd and try it again
Posted on Apr 15, 2009
  • 85 Answers
SOURCE: DVD/CD writer
This is a common problem on HP laptops. Try updating the firmware on the DVD drive by searching on the web for the make and model number of the HP laptop and going from there.
Good luck...
Posted on Nov 16, 2007
  • 263 Answers
SOURCE: hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Posted on Jul 30, 2009
benwabnick
  • 2404 Answers
SOURCE: HP 530 laptop. Vista Home Basic OS. 18 months old.
the motor went bad in the drive if its not even trying to spin the disc. The only option at this point is to get the drive replaced.
Posted on Sep 04, 2009
shafykp750
  • 1070 Answers
SOURCE: CD driver will not start
Dear Friend You have To Do Following
  • Check your Disk(as Damaged) you are about to start
  • Clean your Driver using any Lens Cleaner CD
  • Change another CD
  • Reeboot
Most of the CD drivers will DETECT directly ...No need to be Install any Driver(Software installation).Still problem exist,try another CD ROM
You are Done....
You may Fell free Contact me...
Posted on Mar 31, 2010
I have a spi 2gb mp3 player and have lost the software disc i cannot find anything online to help me and the tech support for the spi site goes to an unbought site for godaddy.com this is ridiculous. win 7...
Try another computer (if available) to see if the player is reconised by that one. If it is reconised, there may be something wrong with your computer (windows should still reconise the device as a mp3 player, but would not be able to open it without the drivers). If you can't try another computer, try a linux live cd (I recomend Ubuntu http://www.ubuntu.com/) the live cd will not modify your computer unless you tell it to. To use the live cd insert it in the cd drive, reboot and in the bios menu select boot from cd. Using the live cd will allow the computer to run linux (another operating system) without installing it, meaning that you won't need to worry about iharming your computer. I reccomend this because if you use the live cd, you will have a different OS looking at the device, like having a fresh set of eyes, and it may be able to open the player (Ubuntu has great driver support).
Jul 18, 2010 | Computers & Internet
Player will not read cd . Cd will not spin
Without me seeing it, it usually cannot read the disc and is caused by a defective, or needs to be adjusted or cleaned, laser assembly as long as it is every cd put in it. It can also be the disc spinner motor. Either one of those is the most likely cause. :)
May 19, 2010 | Yamaha CDC-845 5-Disc CD Changer
The cd gets ejected without being read.
As long as it does that on more than 1 disc, it can be a couple of things. The lid has to be taken off so you can see and listen to what is happening. #1 If it takes it all the way in and spins the disc, it most likely cannot read the disc usually because the laser lens needs to be cleaned or the laser is defective. You will hear the lens going up and down, making a clicking noise over and over and then it ejects it. #2 If it cannot load it all the way in and does not even spin the disc, it is usually a rubber loading belt is slipping and needs to be cleaned or replaced. You will hear the motor running and running without taking the disc all the way in. It will never spin the disc, then eject it. Other things can cause it also but those 2 are the first things to look at. :)
May 19, 2010 | Audio Players & Recorders
System locks up when cd is inserted
The auto-run feature is probably forcing the drive to attempt to read the CD, and if the disc is corrupt, can cause the system to "freeze" while it attempts (and fails) to read the bad disc.
If you've tried mulitple discs, or one that you know works in another CD-ROM drive, it could be the CD drive itself. If that's the case, you can pick up a good CD/DVD writable drive for $25-$50, and takes 5 minutes to swap out.
Oct 05, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
CD drive will not read my discs and does not recognize cd in drive.
Try to run a head cleaner on your laptop drive CD/DVD drive. After cleaning if it still does not read any discs, then it probably time to replace it.
May 30, 2009 | Dell Latitude D600 Notebook
18 year old Beocenter 9300 CD won't play most CDs
cd unit unable to read disc,replace or try cleaning laser lens.cd clamper may be misaligned or faulty,check operation in service position(top up).
Dec 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
My PC
Maybe your cd cannot be read anymore by your CD drive.
be sure that the cd is cleaned and no crack traces on it.
Please try another a very new CD/DVD to see if the CD drive can read.
if read then, your cd is damage. but there is some CD drive that cannot read some cd disc. You should select maybe the cd rom compatibility.
Dec 28, 2007 | Dell Dimension 4600 PC Desktop
Cd Changer will not play CD's
hi does it then say no cds? does it try and load the tray? sounds like it is not reconising that any cds are inserted, could be the laser, faulty or the tray is not reaching the tray in/loaded switch. not worked on many jvc units, so it a bit of guess work regards Mark www.carradiospares.co.uk
Jan 08, 2007 | JVC CH-X470RF 12-Disc CD Changer
HP G60-235DX Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
