Question about Volvo Xc70 02 2002
I just replaced a coil pack in my 2002 volvo xc70 because it was driving really rough. it seemed to fix the problem. just driving the car and started making some noises, after which it made a really
After the big clunk sound, smoke from exhaust pipe.
  • joec Dec 31, 2012
    it made a really loud noise - like a clunk - and then just stopped running. is the car dead? has 280K miles. not sure it's worth sticking more $$ in.
  • 53 Answers
I would do a compression check. They are easy to do. The tool is about $50 at any part store. If you have a harbor freight near by it's only $30.
If that is something you're willing to try let me know and I can talk you through it.
Posted on Dec 31, 2012
Testimonial: "thanks. yes, that sounds like a good place to start. i'll let you know. thanks again."
How do the crankcases gasses get into the intake air chamber of my 2002 volvo xc70 and does this or can this make the ngine rough
It's possible that you may have either a clogged breather box or broken breather box hose. The breather box is located under the intake manifold. It is sometimes also called an oil trap.
May 04, 2014 | 2004 Volvo XC70
2002 pontiac grand am se1 6cyl is idles rough
what mileage,spark plugs,fuel filter[,coils module,this #1]
Feb 22, 2013 | 2002 Pontiac Grand Am SE
Replaced plugs and coil pack on 2001 ford taurus now car will not start
You will need to figure out if you have spark to the plugs, and if not- if you have voltage to the coil to proceed.
Aug 04, 2012 | Ford Taurus Cars & Trucks
2002 volvo s60 cylinder 3 misfire detected
I have a bad feeling. I own a Volvo SW XC70 and I had to change the timing belt because I didn't want to have to buy a new engine. I changed it at around 150K miles. The belt is a composite and is not a chain (metal), so it can stretch, thus giving you "bad" timing and making it impossible to tune. If you have not checked or changed the belt, try it. It really won't cost that much (depending on where you take it. I went to Volvo. Good luck.
DON'T DRIVE THE CAR UNTIL YOU ARE SURE.
Dec 11, 2011 | 2002 Volvo S60
Have a p301, p305 codes (misfires) and p401, Engine runs really rough. 120000 and never changed spark plugs. Could a simple tune up fix this. Also replaced the egr back pressure sensor. What else could...
It is most likely an ignition system problem so starting by replacing the spark plugs and wires ia advisable.
If the problem persists then have the ignition module, and coil packs tested.
Feb 03, 2011 | 2002 Mercury Mountaineer
Volvo xc70 in limp mode 7 fault codes recorded d5
Possible problem with the alternator not putting out enough voltage. I had the same problem with my 2002 XC70, putting in a new alternator fixed it. I used a local mechanic who I found on the car talk web-site. Low Cost Volvo parts can be purchased at FCP Groton.
Apr 22, 2010 | 2003 Volvo XC70
Volvo XC70 I have had several computer errors
Check two items, chassey grounds by battery, transmission and starter. Also, check to make sure the alternator is providing enough voltage, should be around 14 amps. Had a similar problem with my 2002 XC70, replacing the alternator fixed it! I used the Car Talk website to find a good local mechanic vs. the stealer.
Oct 21, 2009 | 2004 Volvo XC70
2002 kia sedona 3.5l has rough idle replaced plugs wires and coil
this vehicle has coil packs for the ignition correct? have you ran the engine at night with all surrounding lights outs so its really dark. spray a mist of water on the coil packs and spark plug wires to see if you have spark/voltage leaks jumping out from them. sometimes the tiny sparks will be so fine and skinny you can barely see them so it needs to be dark. hope this helps your trouble shooting. a coil pack could have such a fine crack for the voltage to leak from that you cant see it.
Jun 13, 2009 | 2002 Kia Sedona
1990 ford ranger 2.3L running rough at idle and while driving
Hi check all the fuse. fi the fuse are ok . remove the coil pack and reverce if the cly missifire change replace the coil if not chage replace the electronic comtrol module ok.
Apr 20, 2009 | 1990 Ford Ranger SuperCab
Rough to start.
Fold the rear seat cushion forward so you can see the carpet covering the floor board.
Kind of pull up on the carpet area and check to see if you smell gas.
Most common problem we've been seeing is the fuel pump leaking and should be covered by an extended warranty.
Jul 07, 2008 | 2004 Volvo XC70
Volvo Xc70 02 2002 Logo
Top Volvo Car Audio & Video Experts
xxxxxx xxx
Jax Planet
Jax Planet
Tom Chichester
Are you a Volvo Car Audio and Video Expert? Answer questions, earn points and help others
