Question about Cell Phones
Won't boot up. Error message "
Unit was not dropped, dunked or any other trauma. Was plugged in for about 4 hours while on. When I went back to get the unit it was off. When I tried to start up the phone I got the error " Bootloader 30.04 Battery Low Cannot Program " on an otherwise blank screen. After a minute or so the unit went blank again.When I push the 'on' button on the top I get a very quick 'yellow' flash and then a constant 'green light'.
Did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Posted on Dec 31, 2012
teddc
  • 115 Answers
SOURCE: need bootloader 06.A3, Err:a5,69,35,00,2E
This is an internal software error. If your phone is less than 1 year old you can get it replaced at no charge from your provider. If it is over 1 year old you would need to use your insurance if you have that option. Point is, t he phone will need to be replaced.
Posted on Apr 21, 2009
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: My Sony Ericsson K770i phone
i just had the same problem.. did you find out what it is?
Posted on Aug 01, 2008
133712ap3
  • 22 Answers
SOURCE: I have a Motorola RAZR
Despite this comment comming late - Razr's have had issues since their release. In particular, the CDMA Razr's have had serious issues (V3c, V3a, V3m). Your V3m has a serious flaw in the software which actually caused them to discontinue it. If you put the microSD cards that it accepts into them & put too much music on the card for the phone (how much isn't disclosed), the phone can become unstable & even unoperable. As far as the quantity goes, I put 5 songs on my 1GB microSD after the card was formatted by the phone & the thing immediately white-screened. Its a common issue with them. Since this is a flaw in the phone itself, you should be able to b*tch about the phone to the phone company & have it replaced with a different model. Keep in mind, there is a circular sticker on the back that detects water damage. It will turn red if water touches it (humidity, or if you clean your phone with an alcohol wipe like I do). You might want to consider swapping that our with a clean one or just tell them you wiped the back with an alcohol wipe. Either way, hope this helps you or other people.
Posted on Jun 24, 2009
SOURCE: Black screen Sony Ericsson K850i
I just had the same problem. I tried everything including resetting the whole phone upgrading the software etc etc.
I was convinced it was a softare problem, but my screen only went black when i press the buttons on one side of the keywpad so i started thinking it may simply be hardware related.
I tried taking off the case but didnt have the screw drivers to do this.
Eventually in a fit of rage I threw my phone on the floor (Carpetted floor) and too my surprise the problem got better! I basically gave my phone a few more whacks and it started to work fine again.
I am not suggsting you start whacking your phone, but i imagine if you took off the case and re-fitted it this would work.
Good luck.
Posted on Jun 27, 2009
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Lenovo 3000 J Series won't boot up. It beeps 4 times and does nothing.
the only beep code i can find for 4 beeps is a keyboard error. if you're using ps/2 you should make sure you haven't put the plugs in the wrong ports. i found the information here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_pdf/41t3751.pdf
page 75
Feb 16, 2012 | Lenovo Computers & Internet
Getting an E1 error message..wont start
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
My Seagate freeagent 320GB won't show up on my computer. It was working fine yesterday when I backed up some important folders, then later on that day, I went to add something to it, and it told me...
Get the Testdisk app and see if it can identify the issue. You can repair the boot sector or create a new one with th is app. If it shows up in the drive list you have a good chance of getting the drive back.
Mar 06, 2017 | Seagate FreeAgent Pro Desktop - 320GB -...
Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Jul 15, 2008 | Sharp AF-S100FX Air Conditioner
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
