Question about Amana Washing Machines
The tub on my washing machine model # AAV70000AWW seems to be off center water will not spin out
It appears that the machine is level
  • Amana Master
  • 17,130 Answers
Possible that the drain pump is clogged with the valve not flushing out. Make sure there is a slight tilt to the drain side of the TUB, now if you can remove and clean the drain pump and outlet it might solve the issue.
Posted on Dec 31, 2012
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
dididsaythat
  • 291 Answers
SOURCE: washing machine
what kind of washer and model # ? Sounds like.. You have a bad pressure switch or the small hose connecting to the pressure switch may be bad or the connection on the switch or tub is linking air pressure I seen where mice had chewed holes in them
Posted on Aug 29, 2007
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
pumpkinman
  • 1144 Answers
SOURCE: shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Posted on Jul 01, 2009
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
My Washer Baskets is leaning to one side when washing and spinning
Hello penpoint1959 - The tub is stabilized in the center with multiple springs which attach to the base of the washing machine and the frame of the tub. If one of the spring(s) is loose or broken, this may result in the tub being off center. Other possibilities are, the unit is not level and the load of clothing is not balance evenly in the tub. I personally first verify that the unit is level and the unit is being loaded evenly. If correct, and if I was in your position I would contacting a certified technician to move forward accurately and to assist with the repairs.
Feb 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
Drum seems out of balance does not allow water to drain because water pump hose kinks
Hi, you will have to open machine, and check spring, maybe one of your spring are broken, or strain, first lift top, and remove sides of machine, put hands on tub and rock complete assemble back until tub centers, if tub is tilted left, spring on opposite side, is loose or broken, if broken, replace, but most time they slip out, this is cause, if machine are overloaded, or not level properly, when washers are not properly leveled, when they reach spin cycle, they could go outside and come back in, just making a point, check you machine level before you start. good luck.
Aug 07, 2009 | Maytag PAV3240A Top Load Washer
Tub goes out of balance every spin cycle
If it doesnt bang and crash around or doesnt seem like there it is out of balance (ie try running with nothing in it) then theres probably and electronic component problem
Jul 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
