Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
Want to bypass oxygen depletion sensor - Mr. Heater Mr Heater Portable Buddy Propane Heater
  • Mr. Heater Master
  • 2,598 Answers
You cannot its for saftey
Posted on Dec 31, 2012
What are the probable causes of DTCs P0030, P0039, P0074, and P0098?
code p 0030 refers to heated oxygen sensor (HO2S) 1 bank 1 -heater control-circuit malfunction
code p 0039 refers to turbo/super charger bypass valve , control circuit --range /performance problem===causes --wiring--- bypass valve
code p 74 refers to outside air temperature sensor--circuit intermittent===causes ---wiring---poor connection---out side air temp sensor---ECM
code p 0098 refers to intake air temp (IAT) sensor 2 --circuit high input===causes --wiring short to positive ---IAT sensor---ECM
Nov 23, 2015 | 1994 Cadillac DeVille
My gas fireplace shuts off after burning about five minutes - both main burner and pilot shut off.
Most fire place burners have an oxygen depletion sensor on them nowadays. If you can restart it after a while, a few minutes or so, and shuts off, it is probably the oxygen sensor. The owner lights fireplace and shuts the door, and the fire depletes the available oxygen and the fire will start producing copious amounts of CO which is a hazard. Most fireplaces have a fresh air supply available to provide combustion air but needs to be opened for the fireplace to work properly. Check the manufactures recommendation as to the proper installation of the fireplace furnace.
Hope this helps
Feb 05, 2015 | Heating & Cooling
How to fix code 13 on a on demand water heater rmtgh95dv
Check the venting and then phone rheem for the how to on clean and testing the oxygen depletion sensor
Jul 02, 2014 | Rheem Water Heaters
I have richmond rmtgh95dv on demand water heater code 13 shows up and i have no hot water how do i fix this ?
Call rheem for the how to on clean and testing the oxygen depletion sensor and check the venting
Jul 02, 2014 | Rheem Paloma Tankless Water Heaters...
How do i bypass my o2 sensors on 02 Chevrolet
Oxygen Sensors Monitor Exhaust Converter
Efficiency & Oxygen Content
Have to be there or you have no fuel
control
Need to study OBD2 Systems
ALL Components that came on any
vehicle is required by federal law & has to stay
Feb 19, 2014 | Cars & Trucks
POLIT GOING OUT
im assuming its a vent-free unit,dis assemble and clean oxygen depletion sensor,which is incorporated in piulot assembly.
Feb 16, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Need Dyn-Glo Model RMI-70 ODS (Oxygen Depletion Sensor
Most of the time all you need do is blow out the sensor.
They don't wear out.
Dec 22, 2009 | Dyna-Glo RMC-8001SS Heater
When the flame goes out, So does the pilot light
what kind of heater do you have? is is a vent less heater because if it is the main reason it would shut off is the ods(oxygen depletion sensor). make sure that the heater is not too big for the room. also purchase a carbon monoxide detector
Nov 06, 2009 | Vanguard International Blue Flame - Large...
Glo warm heater
These are vent-free heaters and use an oxygen-depletion sensor to shut a unit off if there is not a sufficient amount of oxygen available for combustion. It is either doing it's job and you may have to open or crack a window while it's operating.
Feb 07, 2008 | Heating & Cooling
Heating & Cooling Logo
471 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
