Question about Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover
Xm2002 gtw sony xplod amp - Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover
2 Suggested Answers
loft404
  • 11 Answers
SOURCE: Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Posted on Jun 17, 2009
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 2-Channel 1000 Watt Amplifier trouble shooting
What's the model number of the amp?
What speakers do you have on the amp?
Are the speakers moving significantly at high volume?
Sep 13, 2008 | Car Audio & Video
Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
