Question about Kenmore 2.1 cu. ft. Compact Portable Top-Load Washing Machine 4472
Have a sears model number 11044722401, the washer will run but only so far the the lights for the cycle will all light up and the water level flashes and you have to press the start button to start the machime again whats going on with this please..
    New Friend:
I have the same machine but it won't turn on at all. I plug it in and all lights come on for a second then its completely unresponsive
Posted on Dec 26, 2015
jsrock516
  • 5911 Answers
SOURCE: Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
Posted on Jun 03, 2007
SOURCE: he2 washer flashing code f51
check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
  • 521 Answers
SOURCE: Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Posted on Aug 24, 2008
mgprice
  • 744 Answers
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
How much water does a 7kg front loader use?
Depends what cycle it's used on. For example "Spin" uses no water at all.
If you want to measure it, run a cycle without laundry, and mark on a piece of paper tape stuck to the porthole how far up the water level reaches. Count how many times the machine empties and refills during your chosen wash cycle. After the final spin, close the door, and slowly refill the machine via the detergent drawer from a graduated jug or watering can, until the water level reaches the mark on the porthole. Multiply the volume poured in by the number of cycles, and there's your answer - approximately.
Feb 03, 2018 | Washing Machines
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Haier top load washer: washes and drains but stops working at rinse cycle. Super capacity model but no model number I can find. The unit is about 6-7 years old.
Call Sears or GE service...either can address the problem. They may offer you a one-year contract, which is worth the price. If they can't fix it, you will get a credit toward the purchase of a new unit.
Nov 02, 2017 | Haier Washing Machines
Kenmore washer model 11044722401 how to manually advance the cycles? Sears technician showed me how a few years ago-- so I know it can be done. It is a technician diagnostic test/ function.
With the washer off, unplug it and plug it back in the lights should blink twice. Then press the wash temp and water level keypads at the same time. The water level should stay on but all others should stay off. If this happens the washer is in diagnostic test mode. Hope this helps
Nov 04, 2016 | Kenmore Washing Machines
Bosch Vision 800 Series front loading washer. Flashing "water level is too high". We are not getting any water into machine at all. Is there a way to reset?
We had this same problem last night, although we had just purchased this washer 'new' (bought it at Sears, display model, and it's 9 months old but had not been used). We didn't even get the correct user's manual with it, but after running one cycle without laundry the message went away.
Aug 09, 2010 | Audiovox Bosch 718 World Cellular Phone
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Kenmore 2.1 cu. ft. Compact Portable Top-Load Washing Machine 4472 Logo
161 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
