Question about Dryers
My Maytag 6400AYW dryer does not heat. Vent was clogged. I cleared but it still does not heat. Smelled metal burning prior to problem. Appears that I need to replace thermal fuse and hi limit ther
Want to avoid repairman. How do I access the thermal fuse?
  • Mike Jaros Jan 01, 2013
    I removed thermal fuse and hi-limit fuse. Both test OK on meter. Then I removed and tested the heating element. There was no continuity. Took it out of the canister, and yes, the element is broken. Stores here did not stock so I ordered the part from Sears. Due to New Year's holiday, it will take a week. Still saved a lot over hiring someone. (This is assuming that the heating element is the part.) Thanks again Bill.
  • 433 Answers
You are on the right trac.
The easyest way to check the thermal fuses is to follow the wires from the heater element up to the control board and put a meter across the thermal fuses, most dryers have two, you unplug the leads remvoe and replace.
Unplug before you start.
Check you model number again, and then go to the sears web page and you will be able to pull diagrams of the unit, I tried and you have an error
Posted on Jan 01, 2013
  • 300 Answers
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Mar 07, 2009
SOURCE: Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Posted on Jan 04, 2008
bruce508
  • 44 Answers
SOURCE: Dryer heats then stops heating.
If the cleaning helped before, maybe something is still clogged. Check particularly the area around the lint filter. Take it out and see if you can remove lots of lint, maybe with something like a coat hanger and a bit of skill and care. I have found air passages to lint filters crammed, particularly when people have neglected cleaning the filter.
Sometimes, if the room is dark and you look the right place (like maybe the back panel grill), it is easy to see the light of the coils turning off and on. Sometimes that behavior can provide a clue.
Posted on Jun 29, 2009
canbruce75
  • 1776 Answers
SOURCE: maytag dryer model #mde6657byw wont heat replaced
Check the switch mounted on the motor. Two of the terminals are for the heater element operation. Other causes could be a faulty heat selector switch or timer. These components can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity indicates a faulty switch. These are some items to consider. Hope this helped and best wishes.
Posted on Aug 31, 2009
milten1
  • 1304 Answers
SOURCE: Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Posted on Oct 21, 2009
Testimonial: "Thanks, I'll replace everything! "
Maytag EPIC dryer runs but does not get warm and therefore the clothes do not dry.
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Aug 05, 2011 | Dryers
Dryer problem
have ou check the heating element, the thermal fuse..?
Jul 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Too long to dry my clothes
HI,
Vent
Heating element
Internal ductwork
Cycling thermostat
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
Heating Element Won't Shut Off
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
Vent
Heating element
Internal ductwork
Cycling thermostat
May 26, 2008 | Maytag 24 in. MDBH955AW Built-in...
My Kenmore 600 is not even 2 years old. It spins and appears to have heat but the clothes do not dry. I cleaned a ton of lint from the flex pipe/elbow joint in the rear of the dryer but this has not...
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
I have model #MDE6400AYW - my dryer does not turn on. I have confirmed the power source works, the vent is clear, I have replaced the timer, and even confirmed that both thermal fuses work yet my dryer...
Hello, I will assume this is a electric dryer where the drum turns but no heat, your problem most likely is the centrifigal switch. this is built into the motor. Basically its operation is to not switch the heater2.gif on unless the motor is turning. By the sound of things you are compitent with electrical side of appliances. Remove the wire harness for the motor. Make up a wire bypass using 2 male connectors and some heavy duty wire. plug each end of this bypass into the wire harness where you see the 2 thick wires. Next making sure the harness is not touching anything metal plug her in and hit the start button, check to see if the heater starts to glow or you can smell it heating up...if it does heat up your going to need to change the motor. If this is not your problem please don't down rate me, feel free to comment again and I will give you further help. Mike
Sep 22, 2009 | Dryers
Electric Maytag dryer won't turn on after burning smell
LA 1053 Thermostat kit and the vent/ Lint collection probably clogged. When overheats its safety feature is to kick the thermostat offgetimage.ashx?imagetype=item&mfgname=maytag&brandname=maytag&idealitemnumber=la1053&standardimagesizecode=web_displayThermal fuse
Feb 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
