I have a LG front load dryer. We smelled a burning smell. Now the dryer will not power on but the inside light works and the tub turns ! Could this be the thermostats ??
  • Washing Mach... Master
  • 17,130 Answers
Need to trace the location of the burning smell and if this points to the main power supply or board then an examination will show up the damaged part, it could be a mains filter capacitor or a surge protector.
Posted on Dec 31, 2012
SOURCE: Moldy smell in front load kenmore washer
What you all are forgetting and I can vogue for this and prove it because we ripped our washer down......and I have pics... the mold will collect behind the SS tub in the plastic drum housing... every repair man told me NO POSSIBLE WAY!!!! well I was so sick of being sick and my husband decided time to buy a new washer we did and a (top loader i will add). and when the top loader was delivered we ripped the front loader totally apart (any one that would like to see pics you can email it) but be forewarned they are GROSS!!! I have done all the maintenance they have recommended and nothing helped (bleach, cascade, OXY, vinegar, leaving door open (which i may remind anyone is a risk if you have toddlers ) oh yes and lets not forget the washer magic they push down your throat to buy every time a sears tech comes out) I have a family of 6....4 girls and 2 of them babies so I have a lot of laundry....I will be more then happy to share what we found was hiding in the washer's this is not something you can see until you rip it totally down. CJ
Posted on Sep 26, 2007
SOURCE: Strong meldew smell from washer
Clean out the drain filter. mine had one of my kids socks stuck in it. Any small item could get clogged, it is best to use a laundry bag for those items.
Posted on Jul 13, 2008
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Posted on Sep 14, 2008
  • 3 Answers
SOURCE: Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Posted on Oct 16, 2008
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Posted on Jul 09, 2009
My LG wm2050cw front load washing machine had a burn smell in the drum, first time I ever noticed it. Any help with diagnosing much appreciated!
As a good guess, I would say it is your bearing seal. That's about the only thing that would give a burning rubber type smell in the drum/tub. Try moving the tub forward and backward and see if it moves. It should not. If it does that's a sure sign of bearing problems. Hopefully it is something else. Bearings are a difficult fix.
Jan 09, 2017 | LG Washing Machines
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Dryer has a burning smell
My Kenmore 94702 dryer element overheated and the rubber inside the tub caught fire. Can anyone tell me how to find out if this problem has been reported by other owners of the Kenmore model or owners of the same model sold by the actual manufacturer?
Mar 20, 2012 | Kenmore 94702 Front Load Stacked Washer /...
My LG is making a burning smell.. but only sometimes. I see no smoke and I have cleaned the vents (front and back) but both are clear... HELP!
could be a few different things... there is a idler pulley on the bottom inside unit that guides belt while tub is turning the pulley could be going out or hanging up and it is plastic/ also could be burning belt up from the pulley not working properly....
Jul 20, 2011 | Dryers
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
Our dryer gave out a burn smell like a belt had broken, and even though plugged in, it will not come on. We took it a part some and didn't see anything wrong. We only took down the front facing to see the...
Dryers have a thermal fuse... typically a ceramic assembly 2-3 inches filled with resin and wires attached...usually near the motor. This may account for the burn smell. Turn the power off and replace .
Dec 08, 2009 | Crosley CDE6000 Electric Dryer
Kenmore 800 dryer burning smell and noise.
Access is from the front. Lint screen on top? 2 screws under screen, putty knife to release front clips between top and cabinet. Top folds back and 2 5/16 screws in top corners. Lean front towards you then lift up off lower hangers. Good luck.....
eric
Jun 06, 2009 | Kenmore Dryers
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
