Question about Hobby Zone Hobbyzone Zig Zag Racer 3 Electric Rc Boat
How to fix a rc boat that works out of water but not in
When i put it in the water it works for a second then stops but,it works fine out of water. I can mess with the levers for a while and it works but,only for a few seconds.
Change the esc its been wet and caused a electrical short. its almost cheaper to buy another zig zag or a totally different boat rather then repair that one.
Posted on May 20, 2013
SYMA RC CENTURY BOAT DOESN'T WORK OUTSIDE WATER
Actually the Syma Brand Boats are designed to not to work out of water. It is a safety feature. You can bypass that if you like. You remove each wire that is soldered to each propeller shaft and twist them together.
Apr 10, 2014 | SYMA Toys industrial 30" RC SYMA Century...
My Double Horse 7000 RC boat will not run
myy was working then stoped. Battery was full. I disasemble it and found that the on/off switch stoped working because of the rust (water is getting inside). I manage to make a direct conection solding the black and red wire in this switch. Try it.
Jan 02, 2013 | Double Horse Radio Remote Control RC...
Hi i just bot a bass boat with a 40 hp mercury motor that has ben sitting up for 8 or ten years. so what should i do before i try to start it again because it wont start at all
First know that they have a neutral safety switch which will stop the motor from spinning if the gear is engaged. so put it in neutral first.
Second- will it even go round? take the hood off and try to spin it by hand. Just to see if it is free. If it is stuck, check the lower unit oil for a lot of rust and water. That will stop it too.
Next - charge or change the battery,
Take the spark plugs out and see if there is any compression, or are there metal pieces found on the spark plug?
Then- or first- buy a book on your motor and a general book on boating.
Practice un-tying the boat and moving it off the trailer at home so you don't look like a novice at the ramp.
After 5 years the water pump should be serviced- use a garden hose and flush attachment or trash can full of water when running it at home- don't forget to put oil in the gas.
Dec 06, 2012 | Boating
How is the prop shafts removed for maintenance?
There is no way to safely remove shafts, it's not designed to be maintenanced, it's a toy, not a top quality boat.
Sep 01, 2012 | SYMA Toys industrial 30" RC SYMA Century...
Engines might run for a second but very sporatic battery is good it acts like there is a short in the system
The boat has an issue that is for safety only allowing it to work in water, this can cause sputtering. You can try to connect a copper wire between the two copper drive shafts. The range on this boat is not great so that may be part of it.
Mar 20, 2011 | SYMA Toys industrial 30" RC SYMA Century...
When i put it in the water and start going it works for a few feet in my control then it starts going in circles
the battery sometimes doesn't get charged very well. When the batter is low, it goes on auto pilot. When this happens to me, I'm usually turning the boat, which makes it go in circles until the batter dies. I learned that keeping the battery cool when charging will help it charge better to prevent this until fifteen or so minutes.
Aug 19, 2010 | Hobby Zone Hobbyzone Zig Zag Racer 3...
RIVA AQUARAMA PROBLEM
You should never run the boat out of water! The shafts heat up in the shaft tube and freeze up. Then your done.
I own a company "H2O Hobbies"
We sell ready to run Riva boats such as yours. Many other people sell these same boats from the same manufacturer in vietnam. BUT - These are display all models.
My company works with the manufacturer to create each model with removable covers to access the motor etc... inside. The models are made waterproof by lining the inside of the hull with fiberglass. We use high quality brushless motors (1) with hardened steel u-joint coupling to the shaft which is 4mm stainless steel and attach a beril-copper balanced propeller. This setup is bulletproof. It took about a year of testing several different components to find the right set of matched components to get the best performance and reliability.
We use 2 7.2v battery packs in series = 14.4v.
See youtube videos - search scalemodelpowderful.
My suggestion is to put your boat on a shelf because that is what is was made for and buy one from us which is waterproof and accessable to work on if necessary. Go to H2OHobbies.com or call me 612-325-2345 - Mark I am the Director of product development. I build the RC boats myself.
Jan 14, 2009 | Handcrafted Model Ships Riva Aquarama Blue...
Samsung dvd-r155 unlock region code
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Works just fine on my region 4 R155. Hope this helps.
Aug 03, 2008 | Televison & Video
Hobby Zone Hobbyzone Zig Zag Racer 3 Electric Rc Boat Logo
202 people viewed this question
Top Hobby Zone Toys Experts
ray gallant
Are you a Hobby Zone Toy Expert? Answer questions, earn points and help others
