How to change a filter in amish heat surge heater
4 Suggested Answers
  • 4736 Answers
SOURCE: my amish heat surge heater
Sadly, the only thing that is Amish on your heater is the cabinet mantle. The electric fireplace is made in China. Never-the-less, from what you describe, it appears that the heater coil is not receiving power or it has burned out. If it's not receiving power, one of the resistors that controls the power to heater has gone bad (probably melted). The bulbs being burned out does not affect the heater. You must have had this unit for sometime for the bulbs to burn out. Normally these are LED Bulbs that have a tremendously long life. It may be that the bulbs have vibrated loose and need to be re-tighten.
If I recall correctly, these units were sold with a one year warranty and may have had an option of an extended warranty. If yours is still under that one year warranty, you're in business. If you purchased the extended warranty, that's even better.
In any event, contact their customer service dept @ 1-800-924-7964, as they may able to help you even more.
Posted on Jan 20, 2011
  • 4736 Answers
SOURCE: how to change bulb in amish heat surge heater
It's not difficult to change the bulb. But lengthy to explain. If you no longer have your Owners Manual go the link below and click on "Flame does not illuminate properly" More than likely though, the bulb(s) have just come loose.
http://www.heatsurge.com/help/troubleshooting.cfm
Posted on Jan 21, 2011
  • 4736 Answers
SOURCE: How do you change a light in an Amish surge
To do it correctly you'll need to see a drawing or picture. It's not difficult and the bulb may only be loose. They do that sometimes from vibration.
For more information and a downloadable manual do to:
http://www.heatsurge.com/help/troubleshooting.cfm#poor-light
If the link doesn't work when you click on it, simply copy and paste it into your web browser.
Posted on Jan 28, 2011
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
Heat surge amish heater turns off and trips reset button
Do NOT use this unit as is!.
My experience is you have to pay to ship it for repairs and if out of warranty you should buy another heater. All electric heaters use the same power for the same heat unless its a heat pump, so save money and buy $30 WalMart heaters.
Nov 17, 2012 | Heating & Cooling
Heat surge fireplace
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Oct 12, 2012 | Unknown Heat Surge Amish Crafted...
How do you change a light in an Amish surge heater?
Jan 28, 2011 | Heating & Cooling
How to change bulb in amish heat surge heater
Jan 21, 2011 | Heating & Cooling
My amish heat surge heater has to bad bulbs in it. I found that the heater is not putting out heat. the fan works but it won't heat. Is it because the bulbs are burnned out?
Jan 19, 2011 | Heating & Cooling
Heating & Cooling Logo
467 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
