Question about Browning Fishing Midas Spinning Reels
Need a part diagram
I have replace a gear but small spring came out of the reel I don't know we're it goes.
Where can I get an assembly diagram?
  1. Popular Daiwa Goldcast Spincast Reel Medium Heavy ...
    www.fixya.com > Forum > Fishing Rods & Reels > Daiwa
    Popular Daiwa Goldcast Spincast Reel Medium Heavy Action, GC120 questions, common issues & problems. Find solutions, answers, DIY tips, repair advice ...
Jul 20, 2015 | Daiwa Goldcast Spincast Reel Medium Heavy...
My line guide on my 30l tidewater only goes one way what could keep it from going back and forth for an even wind
Most likely a broken spring. Since it goes one way and not the other. Could be a small arm in it That the spring clicks over to retract it. If it is a high dollar reel, you can probably find the part. BTW, this is a car forum. I just happen to fix reels also.
Jun 05, 2015 | Fishing
Where can i get manual for assembling cardinal models10 fishing reel
do you till have the box it came in.many reel companies printed the diagrams on the inside .
Mar 28, 2015 | Abu Garcia Cardinal S Spinning Reel, Reel...
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
Gth2548 25hp 48" - bolt
Hi hoofprintsfa,
Welcome to fixya!
Here is the website for your manual: www.mymowerparts.com/pdf/Poulan_AYP_1/logt25h48a_e.pdf
Copy and paste this address into your web browser and the manual will be ready to download for you.
Here is a website where you can get parts for your tractor. It includes a parts diagram: http://www.partstree.com/parts/?lc=&mn=Gth2548
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here.....
Thanks,
Handie Andie
Jun 21, 2011 | Husqvarna Garden
I have Bell&Howell 16mm film projector. Clean and has worked with no problems. Turned down sound during silent movie. Played next reel with sound but could not get sound. Then the reels stopped...
If you don't know how to service this type of machine, I would contact a Bell & Howell dealer and get it repaired/serviced. It possibly needs the magnetic head cleaning.
Apr 17, 2011 | Televison & Video
I have an Alvey 725C deep sea fishing reel which will not now lock into the stop position. A small wire like spring was found on the floor of the boat so I assume it came from inside the reel, but I don't...
Perhaps this may be of assistance. The spring may be broken and need replacing, match it to the diagram and work it out from there.
http://www.alvey.com.au/downloads/525C52,%20655C52,725C52,925C52.pdf
Feb 07, 2010 | Boating
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Dec 10, 2008 | TDK TC-30HG VHS-C Tape
Browning Fishing Midas Spinning Reels Logo
22 people viewed this question
Top Browning Computers & Internet Experts
David Payne
David Payne
Are you a Browning Computer and Internet Expert? Answer questions, earn points and help others
