HOW TO PROGRAM COMCAST REMOTE TO CONTOL CRAIG TV
I NEED TO PROGRAM MY COMCAST REMOTE CONTROL TO WORK MY CRAIG TV, MODEL CLC512
CompuGuy44
  • 432 Answers
SOURCE: Need code for remote control
Code Search Method: Turn on the device you wish to program. Press and hold CODE SEARCH until the indicator light lights, then release. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit. Press and release off-on until your device turns off. You may have to press off-on up to 200 times. When your device turns off, press the ENTER button and the indicator light will go off. Code Entry Method: Manually turn on the device you want to program. Find the code for your device in the code list. Press and hold the CODE SEARCH button until the indicator light lights, then release. Press and release the device you want to program, the indicator light will blink then remain lit. Enter your code using the number buttons.After your code is entered the indicator light will turn off. Aim the remote at your device and press the off-on button. The device should turn off. APEX CODES: 006,014,033,035,036,039,041,152,247,172, 173
Posted on Sep 15, 2007
pinay311
  • 3 Answers
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Posted on Jan 30, 2008
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Posted on Jun 02, 2008
SOURCE: Help with comcast remote code setup for philips tv
Try adding 1 to the front of the code. 10054 worked for me. Hope this helps.
Posted on Nov 26, 2008
My Craig TV is a year old, I have volume but no picture
contact craig to get warranty service,tell them its 11 months old
May 06, 2015 | Craig Televison & Video
How do I program a craig tv remote. I have a TTXXX126-2D craig remote that I want to program to work with my craig CLC503 TV
If you have a Craig remote you are trying to use with a Craig TV, it should work without need for "programming". The codes are stored in the remote.
Sep 22, 2014 | Redi-Remote CRAIG Replacement Remote...
Cannot program my craig 32" clc512 to phillips srp5107/27 remote control
The programming procedure can be had from the user manual to this remote control. Check this link to download the user manual. If you fail to download, and wants to get details, check this link. It has details about the programming method.
Feb 10, 2013 | Televison & Video
I NEED CODE TO PROGRAM COMCAST REMOTE CONTROL FOR MAGNAVOX LCD TV. MODEL #15MF605T.
If you go to Google an put manual for a Comcast remote control it will give you an option saying, Comcast remote codes, program your Comcast remote control, that will give all of the remote controls just look for yours and download or check the manual for it so that you can program it.
Jan 05, 2010 | Televison & Video
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Mar 31, 2009 | Vizio L32 32 in. LCD HDTV
13" superscan remote with comcast
all cable networks have a manual that shows how to us the R/C [remote control] to SCAN ALL model #s of tvs for all the codes. If you don't have the manual, call Comsast Cable & they should be able to help you.
Note: sometimes a cable network cannot control all TV's R/C because some companies BUY off excess tvs and place their name on the brand.You could be buying Zenith, Sony, RCA !! guts with E.I. "superscan" brand on it.
P.S. sometimes the code is just enought to turn the tv on, raise\lower volume.
Jun 24, 2008 | Televison & Video
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Electro Med Services...
