SOURCE: picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
SOURCE: my remote for my vizio flat screen tv does not
I would think you could use the menu button on the TV to access that feature without the remote.
SOURCE: Comcast picture won't fit in
What you see is called overscan - full explanation here
http://en.wikipedia.org/wiki/Overscan
On your tv it can be removed only when the tv is in PC mode, with the signal coming thru the VGA connector.
SOURCE: The picture on my sony bravia 52 in is huge and I
Try pressing HOME,
Then go to SETTINGS
From the list, select SCREEN
There are now several options that may be causing the picture to zoom.
Try adjusting each setting in the following order, checking if the problem has solved after each change.
Set:
DISPLAY AREA to NORMAL
WIDE MODE to NORMAL
AUTO WIDE to OFF
4:3 DEFAULT to NORMAL
If you are still having problems, you may need to speak to Sony about having the TV serviced as an internal circuit may be broken - if this is the case it may be covered by the warranty.
I hope this helps - if you require more info, here is a link to the Manual for your tv
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/0451c422be8f7211d50375af6ace50aef8fb6504.pdf
u blew a backround bulb it sounds like
