Question about Gateway MB.GAH09.001 Motherboard Desktop Board Fx Series
Doesn't see entire 3TB drives
Unable to recognize 3tb hard disk (shows as 800gb in bios, 746gb windows). Is there a firmware update for this? Or am I completely out of luck and need to replace the board?
  • 2,878 Answers
No. There is a 2TB MBR (Master Boot Record) in Windows.
It needs to formatted / partitioned if new. Type diskmgmt.msc in Search / Run and use the hard drive setup wizard. Highlight the drive and use the refresh icon to initiate wiazard.
You may even have to deleted partition and start from begging. This will cuase data loss. Windows 7 and newer has a dynamic drive option to expand if the partition if not active with the OS.
Posted on Dec 31, 2012
2 Suggested Answers
djbr1ck
  • 158 Answers
SOURCE: I sent i a question yesterday .Still I'm unable to
If the screen shows running in lower power as an error. I think your powersupply isn't supplying enough power to the computer, and probably needs to be replaced.
Posted on May 11, 2011
How can I get Windows 10 to recognize a Seagate 3TB External hard drive?
sorry but anything I tried with windows 10 failed and I went back to old OS thru the control panel and did a recovery .
Oct 27, 2015 | Seagate 3TB Expansion External Desktop USB...
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Bios not recognize new hard drive dell ide
The problem is with your BIOS settings. You need to make sure the drives are set to AHCI in the BIOS.
Sep 21, 2013 | Dell XPS Computers & Internet
746gb hdd limit
There is a limit of 2TB in Windows. You need to ready and break it down. Go to Start > Run / Search and type diskmgmt.msc. You will see the drive there. There you can delete, create, and format partitions.
A wizard might auto load since there is unallocated space. Use the defaults. Each partition is a new drive in My Computer.
Jan 25, 2013 | Western Digital HDD WD30EFRX 3TB SATA Red...
Will an Acer Aspire all in one z5600 support a 3TB internal hard drive
From PC Magazine:
At issue here is a limitation that affects storage media larger than 2.19TB in size, and typically requires updated hardware and a post-Windows XP operating system to take full advantage of. (Read PCMag's article "The Problem with Big Hard Drives" for more information about this.)
For computers to recognize drives any larger than 2.19TB, the MBR and the BIOS would have to be replaced. The successor to the MBR is the GUID Partition Table (GPT), which offers 64-bit block addressing, and thus (when 4KB blocks are utilized) a maximum storage size of 9.4 zettabytes (or 9.4 trillion gigabytes). What's supplanting BIOS, which can't read GPT, is the Unified Extensible Firmware Interface (UEFI), which is built on CPU-independent architecture and drivers and offers more flexibility and features outside of the operating system.
Because Windows XP has no support whatsoever for GPT and UEFI, no system running it can natively use any drive with a capacity over 2.19TB. Even if you have a supported OS (Windows Vista, Windows 7, and most flavors of Linux) that recognizes GPT, you won't be able to boot to a drive of that size unless you also have a motherboard running UEFI-something that, as of this writing in late 2010, very few do. All current Intel boards support UEFI, but almost no other major manufacturer has yet followed suit. So, under most circumstances, if you don't have a UEFI motherboard (and you probably don't), you'll have to use your extra-large hard drive for storage only. (There are worse things.)
Finally, your system's SATA controller must also be designed to recognize 4KB blocks. This isn't necessarily a big deal: As we discovered when we reviewed Western Digital's new 3TB Caviar Green hard drive, the company is including with all its above-2.19TB drives a PCI Express x1 Host Bus Adapter that lets Windows use a known driver to communicate with the drive.
Resources:
http://www.pcmag.com/article2/0,2817,2381127,00.asp
http://www.pcmag.com/article2/0,2817,2373642,00.asp
Jan 24, 2013 | Acer Computers & Internet
Not able to use my new Seagate Barracuda 3TB
you cannot use more than 2TB of volume in WIN XP. As it does not support GPT initialisation, without it you cannot use the hardrive. More information can be found on this link. support microsoft com
May 19, 2017 | Computers & Internet
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
Disc wizard installation
Thanks that is a good tip to remember.
Jul 10, 2012 | Computers & Internet
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
I have the same issue
Win XP will not be able to recognize whole 3TB storage drive. You need to use some kind of 3rd party utility and then partition it and format as well.. AS a note win xp size is limited up to 80-100 GB.
Sep 22, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Gateway MB.GAH09.001 Motherboard Desktop Board Fx Series Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
