Question about Sewing Machines
E1 ERROR ON MY MC6600 JANOME MACHINE
MACHINE WILL NOT SEW
  • Sewing Machines Master
  • 1,564 Answers
A search though Fixya gives a partial explanation. "Something with the motor" Take it in for repair
Posted on Dec 31, 2012
SOURCE: E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Posted on Dec 27, 2006
bargainbox
  • 1388 Answers
SOURCE: janome e1 error
The erreor message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
www.bargainbox.com.au
Posted on Nov 21, 2008
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
SOURCE: Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Posted on Mar 02, 2009
My Janome Harmony 8048 continues to loose its memory which causes an E1 error. What can be done?
Internet research shows this may be a problem that needs to be addressed by a technician. Take it for service.
Questions Answers for janome e1 error
Jun 01, 2016 | Janome Sewing Machines
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
Feb 14, 2016 | Sewing Machines
I have an E1 error on my 4900 QC. Its been unpluged for days but this error still appears please can you help thank you
An E1 error on Janome machines usually indicates a blown fuse on the main board, possibly the result of an overload. You won't be able to fix this yourself but the mechanic at your nearest Janome sewing centre should be able to provide and fit a new fuse. Might be a good opportunity to have it serviced at the same time.
Mar 02, 2015 | Sewing Machines
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
Janome E1 error
If a warrantee job, it will be no charge.
Motor in Australia is $149-00.....plus installation charge.
You could phone or email Janome HQ or another dealer in your country and ask for an explaination of the E1 error to satisfy yourself of what is the likely cause, and a quote to fix it.
Aug 21, 2009 | Janome Memory Craft 5700
Janome 6600p: E1 error
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Oct 08, 2008 | Janome Sewing Machines
Sewing Machines Logo
297 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
