Question about Dell LATITUDE C840 P4 2.2GHZ 256MB 30GB 15.1"ACTIVE CD 56K ENET WIN 2000COA (DELLC840P422GHZ) PC Notebook
When swiching on will not stay on
Power light on,cap lock light on,numbers lock light on for 5 secs then switches off.
can you help
tony
  • 114 Answers
Not good Tony! Try removing the battery. Does it work now?
Try the opposite, no AC and just the battery. Does it work now?
If not, other things should be disconnected. Like hard drive, CD, memory, and virtually anything else you can remove to see if a part had failed and causes the machine to turn off.
Otherwise it might be time for the shop. Sorry. :(
Posted on Jan 18, 2009
When turning a knob on my Siemens cooktop, a blinking "0" appears, and a red lock sign shows.I pressed the lock sign for min 5 sec but it stays on. How doi turn the lock off in order to use the stove?
Hi,maybe if you have not tried it already,maybe switch it off at the mains and swich it back on it may reset its self,hope it works for you.
Aug 16, 2016 | Siemens Cooktops
The question on the hp g42 the f12 lightOrangestay's on And the cap key blinks 1 x every 3 sec.
could be faulty ram or screen faulty,or even over heating,clean out the fan.
Feb 20, 2015 | HP Computers & Internet
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Inspiron 6000 wont start
I had this problem, and I took out the RAM memory cards and put them back in again, and then the computer booted up fine.
Aug 15, 2008 | Dell Inspiron 6000 Notebook
Unlock
According to the manual, it's on the bottom of the scanner. It's a slide switch that should be moved toward the picture of the open padlock.
Jul 18, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Samsung 940BX LCD monitor 9 mos. old, Problem with monitor not staying on. You turn it on, it will come on for about 3 secs w/picture then goes off, but blue light stays on, black screen. Press power...
The IPboard part no. BN44-0012A is bad. We had to replace 5 monitors with the same problem. If under warranty call 1-800-Samsung for repair or exchange.
Korhan Balimtas
May 19, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Alun Cox
