Question about Nintendo Super NES Console
Can't work SNES
I have a cable that plugs into the normal aerial socket in the TV. I have done this but the TV keeps saying there is no signal even though the SNES has the power light on. Have tried this on 2 different TV's but the same is happening. Am I doing something wrong or is there something missing?
    Problem Solver:
  • 19 Answers
Could be several things. If you are using the SNES RF, make sure the channel switch in back is set to either chanbel 3 or 4. along with your TV. Secondly, make sure your RF (or AV) cable that goes from your SNES to your TV is not defective.
Posted on Sep 20, 2009
  • 82 Answers
Is the TV tuned to the same channel as the SNES ?
Both have to be set to channel 3 or both to channel 4.
Posted on May 13, 2009
  • Terry Vaughan Jun 08, 2009
    Is this problem resolved ?
3 Suggested Answers
latino
  • 93 Answers
SOURCE: SNES FUZZY PICTURE
check the aerial cable
Posted on Oct 26, 2007
  • 3 Answers
SOURCE: I'm missing a cable for my SNES but I don't know which one
its an rf cable you can buy third party ones if you search on the internet. also if you happen to have a video cable for gamecube or n64 you can plug that into the slot on the back of the snes and it will work. Im not sure what that slot is called but its the only one that cable will fit into.
Posted on Feb 28, 2009
They keep saying signal is weak check your source connection what does that mean
It means exactly what it says, the signal coming to your television is weak. It is usually bad connections in cable, incorrect aerial positioning in over air or satellite signals.
Remove any input plugs, and check that the wires aren't oxidized, that they are shiny and clean.
Feb 24, 2018 | Sharp Televison & Video
Hi, tv says no signal, have swapped out aerials set to australia dtv, still no signal. Please help.
what type of cable are you using because video av cable looks exactly like aerial coxial cable but electrically they are quite different.Also make sure impedance matches. cable on antenna , cable from wall to tv , aerial socket designed for same impedance.
http://www.bluejeanscable.com/articles/impedance.htm
if you are a long way from tv station transmitter a mast head amplifier would be employed. this could be another point of failure.
May 18, 2015 | Televison & Video
Why does my freeveiw model Hitachi HDR 1632s coad alublkw only allow me to view what I'm recording. The other channels just say no signal check aerial connections ?
The Frie view is a digital recorder, you only can pause while recording. You don't need tapes to disks.
The antena cable goes in on one socket on the back. In the other socket, you plug a 1 meter coax cable and that cable should go into your TV. That should solve the problem, when you want to see the channels you are not recording.
Jan 20, 2015 | Hitachi Televison & Video
My Polaroid HDTV says no signal. What is going on.
  • Have you plugged in the arial?
  • Is it in the right socket?
  • Are you using an aerial cable extender/splitter?
  • Are you using a portable indoor aerial?
  • Does it have built in Freeview?
  • Have you plugged in an external Freeview box if necessary?
  • Have you scanned for channels through the Freeview box?
  • Are you in an area where the analogue signal has been turned off?
  • Have you subscribed to a cable or satellite provider?
  • Are you on the right TV source?
  1. check the back of the tv to see if the aerial is plugged in.
  2. check the back of the tv to see if the aerial is plugged in correctly.
  3. If you are using an aerial cable extender or splitter, make sure all parts are connected all the way up to the aerial.
  4. If you're using a portable indoor aerial you might not be able to get enough signal to produce a picture. Also the aerial might need to be switched on, plugged in or need batteries.
  5. If the TV has Freeview built-in then you will need to scan for channels before you will get a picture. refur to you're TV's manual.
  6. Make sure, if you have got an external Freeview box that it is plugged in and switched on at the wall. Also make sure that it is connected to the TV either by a scart lead or by HDMI cable.
  7. Typically there will be a button on the remote called menu. From the menu screen choose setup. Then choose auto scan. Follow any on-screen instructions. Always refur to the TV's manual to avoid confusion and frustration.
  8. If you are in an area where they have switched off the analogue signal you will need to buy a Freeview box or subscribe to a cable or satellite provider. Freeview is cheep and is a one off payment ( best for people who will only really watch channels 1-5)
  9. Ring up your providers tech support.
  10. To change what input you are viewing, there will normally be a button called source on the remote. If you have connected a Freeview or cable/satalite box to the tv with a scart lead then select scart. If you used a HDMI lead then select HDMI. (There may be more than one of theses sockets so check behind the TV first. They usually have names or numbers by the side) refur to you're TV manual for help.
That is every problem i can think of. If it still doesnt work, take it back to the shop.
Hope this helps.
Jan 11, 2011 | Polaroid Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Feb 22, 2009 | Nintendo Super NES Console
SNES FUZZY PICTURE
Oct 26, 2007 | Nintendo NES Console
Nintendo Super NES Console Logo
509 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
