Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Sl code riviera designer spa - Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
Fault codes leisurerite spa
Bad Sensor.
Normally a High limit.
But... but SL could also mean your spa is in SLEEP Mode!\
It is a Filtration/Heat mode.
You do not want your spa to be in that mode.
Unfortunately, way too many different spa manufacturers out there using 3 party vendors for their controls and so many different models! You will need to know your make, model & serial number of your controller to find out the sequence of buttons to push.
Good Luck
Aug 27, 2014 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
Getting an sl code
What is giving this code? Make and model?
Dec 19, 2012 | Balboa Instruments Pool & Spa
SL display came on. Not heating.
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Hope this helps.
US Parts Center
Aug 31, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
My balboa spa says sl and isn't heating up
SLP or SL Message
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
How do i unlock my hotub i moved into a new house and it came with but i cant figure it out
You need to clarify -
What is locked?
Spa Cover latches. Most of these are 1 of 2 types
1. Uses a plastic key from the front that simply turns to secure the spring latches. coastsider_0.jpgIf you do not have the key, then use a screw driver to twist the lock 180 degrees. squeeze the 2 lower clips on either side and press upward to release the latch. Repeat on the others. If you need a key, we can provide this one for $2.00.
In this design, the latch anchor has a blank face. If this is the type you have and you are missing the key, you will need the key to release the latch. We can provide you a key for $2.00
Topside Spa Controls -
I do not think these models have any lockout feature on the topside control. The controls are manufactured by Balboa Water Group. If you are seeing some 2 character codes on the display, please provide that information here so we can further assist you.
Nov 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
1998 Buick Riviera battery
Make sure that you have the ventilation tubing when replacing the battery. The car is designed to vent battery gases from beneath the car. Substituting a different type battery (without vent ports, a small hole that is located at each end of the battery ) or if you decide to use the battery without the ventilation tubing, you run the risk of an explosion. This is due to the proximity of the battery to the fuel pump, which is also located beneath the seat.Underhood batteries vent naturally into the air within the engine compartment. In your car there is a small hole in front of your battery that leads to the underside of your car.Your tubing is designed to carry the battery's vapors way and direct it out of your car through this hole.
Jun 28, 2009 | 1998 Buick Riviera
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
44 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
