Question about Nikon D3000 D3100 18-55mm
I have a new Nikon 3100. The problem now is my 18-55 zoom lens is locked and it won't move. In the manual setting and by unclicking the outer lens auto button, the focus front lens is fine. It'
    Guru:
  • Nikon Expert
  • 362 Answers
Simple answer; NO! What ever you do; do not try to force anything to move and don't try to disassemble the lens. Contact a Nikon Repair Depot (found in your instruction manual or on the Nikon USA website) and they will give you instructions for returning it for a repair estimate. If it is still in warranty, there should be no charge.
Posted on Jun 17, 2014
80-400 NIkon won't zoom on NIkon D700
Not if your other lenses work ok. I would contact the Nikon Repair Depot that cleaned it.
Jun 20, 2012 | Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR...
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
My N55 won't let me depress the shutter (to take the shot) when it's on automatic setting. I depress once (half-way) for autofocusing--which seems to work fine. No error message. But then, the N55...
Could be your lens is not communication with the body. If the lens is not telling the camera that the AF has locked on an object then it won't allow the camera to fire. Make sure that the camera is indeed locking the AF on the object. If there isn't enough contrast (for example a plain wall) then it wont be able to lock onto it. This would usually explain why it works on manual but not on auto (I assume you mean the focus setting and not the camera's modes). If you're still having issues I recommend you contact a nearby Nikon authorized service center for assistance and possible repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon N55 35mm SLR Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
When mounting either of my Sigma 70-300mmD lens on my Nikon D200 I get the fEE symbol. I've locked the lens at f22 with no results. It's worked flawlessly for me for years. Both lenses work beautifully on...
Have a close look at the iris ring to see if any think is broking off
or try moving the lens when it is locked on the camera to see if you lose the fee if so it may need a new mount
Aug 17, 2010 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D3000 D3100 18-55mm Logo
159 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
