Question about Viper Vehicle Parts & Accessories
I have a dodge ram 1500 and i install a viper 5704 the remote start don't respond
I guess i will need a bypass module
ltfrc
  • 227 Answers
SOURCE: Parking lights will not come on when I use the remote starter
Most alarm installers use in line connectors or crimp-on connectors. If you can identify these connections looking under the dash, you will have to give it a little twist. Usually this allows it to make contact again.
Posted on Jan 11, 2009
SOURCE: 2002 Jeep Grand Cherokee Alarm/Remote start
the12volt.com has wiring diagrams for most vehicles. Including yours
Posted on Apr 10, 2009
  • 11 Answers
SOURCE: how to bypass security system for remote starter
the easyest way to to this is useing DEI Part# 556U you will nned extra key but i think its easyest.or XKO3 if you dont have extra key.
Posted on Nov 10, 2009
  • 50 Answers
SOURCE: I was wondeing if I need a anti theft by pass
yes a spare key will be consumed into the installation using part #
556uw $20-$30
or use canmax part but very expensive $100+ no key consumption.
Posted on Jan 23, 2010
  • 8457 Answers
SOURCE: I need to bypass my viper remote start system as I
Check ur battery take out any extra wire that hook up to the battery.The system should have no power to the Viper system.U should able to start ur car without the Viper remote.
Posted on Apr 21, 2010
Hi I have a 2008 cobalt that the fan speed dose not work I've changed fan itself the resitor I now have it bypassed with toggle switch temporary any ideas
My first guess would be the control module, if the fan has no power and the 30 amp fuses are ok.
The blower is grounded to the body and gets power thru the HVAC control module and the body control module. There are relays and fuses involved. The high speed relay bypasses the resistor.
You may need a wiring diagram and a book to diagnose it.
Jun 17, 2015 | 2008 Chevrolet Cobalt
2000 saturn SL car was broke into ignition switch
I'm guessing the antitheft worked then? Getting the codes and reprogramming a new switch, because it sounds like your switch is damaged probably beyond repair, is most likely a dealer only job. Be sitting down when they tell you how much!!
Oct 20, 2014 | 2000 Saturn SL
Hhr door drivers side wont open
The HHR requires a bypass module which controls the starter resistance, and the door locks. This vehicle has a one wire lock system which locks the doors by sending a certain resistance, and unlocks by sending a different resistance. If you are using a compatible bypass module, check all your connections to make sure they are connected tightly, and then double check the programing you used for the bypass module. You may have to unplug and re-program the module in order to fix the problem. If you are not using a module then you need to double check the wire you are tapped into and double check the resistance. Let me know if this does not apply to what you are doing and if so I will need more info in order to trouble shoot for you.
Apr 13, 2014 | Vehicle Parts & Accessories
Tcm module
TCM ,
how to bypass all transmission shifting?
why?
please be clear.
what is wrong now, ?and or , what is your goal if nothing is wrong.
we can not guess.
Nov 07, 2013 | Directed PLJX GM Self Learning Passlock...
Blower not getting power from TIPM, had a mechanic check it and he said everything checked out fine that the module showed that it was working the way it suppose to, can it be bypassed?
Bypassed for what reason?
You were told it works as supposed to,
have them prove that statement
You will loose all sorts of features
that the module is there for
Just need to properly diagnose the problem
This site has 1,000 people a week come here,
because shops & dealers can't do that & we can't
guess without having the vehicle to test either
Sep 01, 2013 | 2006 Dodge Ram 1500
Auto start on Dodge Ram shuts off about 10 seconds after starting
Not seeing the key chip.The remote that was installed if aftermarket needs to see a key for it to keep running.As with a normal WCM (wireless control module) the keys need to be programed to it.The turning off after 10 second is a security feature and would be normal if a unprogrammed key is used to start the truck.
Mar 28, 2013 | Ram Pickup Alarm Remote Auto Start...
Do i need a bypass module in installing performance teknique 2 way alarm system w/ remote in my 2008 mazda 3
Yes, to do a remote start properly, a bypass module will be needed. The less expensive ones will require you to lose a key. The better one will program to your car using 2 existing working keys. Many online retailers sell them. Look for Fortin, Idatalink, etc.
Feb 20, 2013 | 2-Way Car Alarm System w/ Remote Start
Vehicle Parts & Accessories Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
